Results 1 to 2 of 2
    Vance14's Avatar
    Posts
    Global Posts
    634 Global Posts
    Default Will the phone fit in the dock with a case on it?
    My Thunderbolt dock was purposefully designed to give extra space for phones in cases. What about the landscape dock for the Nexus, will I be able to fit into it with a case on?
  2. #2
    Default Re: Will the phone fit in the dock with a case on it?
    im curious about this myself, having the droid x and the dock and car dock are basically the same where you have to slide the phone on top of the connector M/F... the car dock for the nexus is a 3 pin contact with no insertion needed. I would imagine a case would cause the phone to sit away from the contact point if that makes any sense.
    also for the car dock it looks like it is an exact fit into the dock so just going by the picture i would have to say no.
