- 12-15-2011, 11:39 AM
Thread Author #1
Speed dial?
I can't figure out how to set it up. Ideas anyone?
- 12-16-2011, 01:32 AM #2vanquish (stock rooted)
d2spr (CM 4.2.2 nightly)
manta (stock rooted)
Follow me on Twitter
Email/GTalk
Google+ - 12-16-2011, 02:07 AM
Thread Author #3
Re: Speed dial?
Thanks!
- 12-16-2011, 06:48 AM #4Waiting for the G-Nex
- 12-16-2011, 08:00 AM #5Semper Fi
I love my LG Nexus 4! - 12-16-2011, 08:09 AM #6
- 12-17-2011, 06:13 PM #7vanquish (stock rooted)
Email/GTalk
Google+ - 12-18-2011, 02:09 PM #8
- 12-18-2011, 02:11 PM #9a little obsessive...
- 12-18-2011, 02:12 PM #10
Re: Speed dial?
It is not there. Stock android has never had this. Annoying as hell. I have been using the direct dial widgets in a folder as well, but this should be part of the stock dialer. Really a fail here. I mean it is almost 2012 and Android can't put in speed dialing? There are work arounds but jeez, they shouldn't be needed ..
I still loooooooove my Nexus though :-) - 12-18-2011, 02:18 PM #11
Re: Speed dial?
One solution is you can download Touchpal Dialer from the market.
- 12-18-2011, 02:19 PM #12
- 12-18-2011, 02:23 PM #13
Re: Speed dial?
I used to use speed dialing a lot too. But, I've started using folders for that. At first it took a bit of getting used too. But, I actually like it. I have one home screen that is only for folders with my most frequently used numbers. I have work and family right now. Then I go to the folder, pick the number I want and I'm off.
I also use voice dialing quite a bit through my handsfree. - 12-18-2011, 07:08 PM #14
- 04-16-2012, 10:37 PM #15
- 04-18-2012, 06:02 PM #16Sent from my Verizon Galaxy Note 2, Verizon Galaxy S3, or N7, or MacBook Air
- 07-23-2012, 04:31 PM #17
- 07-25-2012, 08:56 PM #18
- 07-25-2012, 08:56 PM #19
Reply
