Post bugs you find.
Post solutions to bugs if you figure out a workaround.
Prevent redundancy by doing keyword SEARCHES in this thread before you do either.
I've heard that that's how all speakers work basically. I know my OG does that.Anyone notice the speaker sounds like it turns off after every sound? Try this: test a notification or hit the volume rocker on your phone, then right after the sound, listen to the speaker on the back, you'll hear a hiss and then it stops.
Anybody else seeing this???
3:Second problem i have now found. was able to copy over Ring Tones and Notification sounds no problem, but when i went to copy Pictures over in MTP mode it just Hung my PC. Have to copy pictures over in PTP mode to make it work but it's going SLOOOOOOOOOOW. Like USB 1.0 slow. Mind you this is on Windows 7 64bit so......
Click to view quoted image
Post bugs you find.
Prevent redundancy by doing keyword SEARCES in this thread before you do either.
There's a search pulldown above my post to assist you.
I will update this post if a bug is confirmed.
1: can't seem to get Facebook Contact info to sync. Not a huge dealbreaker but pictures and ancillary info was nice to have.
How is LTE for everybody? I'm seeing 3G a lot more than I'm used to, and I've seen other blogger pals saying the same.
Actually no. My OG Droid would never connect to the secure network here at my college. My GN hooks up right away.I cant connect to my secured wifi, every time I try I get an authentication error. anyone else have this problem?
Would love to test, but, uhh... Verizon hasn't covered its home state entirely in LTE, despite it being one of the smallest and most densely packed states.How is LTE for everybody? I'm seeing 3G a lot more than I'm used to, and I've seen other blogger pals saying the same.
