Results 1 to 22 of 22
Like Tree2Likes
  • 2 Post By jas o
    Default LED flashlight
    There's no built-in flashlight app like the Thunderbolt. What's the best one to use?
  2. #2
    tcmeiss's Avatar
    Posts
    Global Posts
    76 Global Posts
    Default Re: LED flashlight
    Well, Tesla LED didn't work for me, and neither did the toggle built in to Widgetsoid.
    Anyone find one that works with it?
  3. #3
    jas o's Avatar
    Posts
    Global Posts
    750 Global Posts
    Take your pick. A bunch to pick from. I just use tiny flashlight + LED
    Waiting for the G-Nex
    Pierce09 and wyseguy77 like this.
  4. #4
    tcmeiss's Avatar
    Posts
    Global Posts
    76 Global Posts
    Quote Originally Posted by jas o View Post
    Thanks. That one works nicely.
  5. #5
    (Waiting for my GN, ) how bright is the light? On my incredible, the light was extremely bright when you put it in overload mode.
  6. #6
    Channan's Avatar
    Keyboard Warrior
    Posts
    ROM
    Stock
    Quote Originally Posted by tcmeiss View Post
    I've only tried Widgetsoid and yeah it doesn't work. I had a sad.
  7. #7
    tcmeiss's Avatar
    Posts
    Global Posts
    76 Global Posts
    Quote Originally Posted by marcw View Post
    surprisingly bright for a single LED. not quite as bright as my Incredible was when you cranked it all the way up, but good enough...
  8. #8
    rmaybach's Avatar
    Posts
    Global Posts
    146 Global Posts
    Tesla LED actually works for me, but there's probably 3 seconds between the time you tap the widget and when the lights actually come on...
    Thanked by:
  9. #9
    tcmeiss's Avatar
    Posts
    Global Posts
    76 Global Posts
    Quote Originally Posted by rmaybach View Post
    which method did you set it to use? just the default?
  10. #10
    the one built into extended controls doesn't work either - even though I have the setting set to LED, it just uses the screen - hopefully they will be updating it soon
    I will try the tiny flashlight suggestion thanks
  11. #11
    got the phone, light works very well
  12. Thread Author  Thread Author    #12
    The best one I've found so far is "Clear Torch". It turns on the camera and the LED light so you can actually see what you've lit up by the LED on the screen. Pretty cool. If they had a zoom function it would be spectacular.
    However, I really miss the one HTC included with the Thunderbolt because it had 3 brightness settings. Using full brightness sometimes is awkward.
  13. #13
    Tesla led is great. I installed this yesterday but didn't wait 3 seconds for the led to light up so I uninstalled.
  14. #14
    pdub73's Avatar
    Posts
    Global Posts
    60 Global Posts
    I downloaded "Flashlight HD LED" by SMALLTE.CH works great gives u both the LED flashlight and an on screen light which u can customize the colors of the backlight....only drawback...ads....1.97 for the ad free version...
  15. #15
    rmaybach's Avatar
    Posts
    Global Posts
    146 Global Posts
    Just the default widget, I didn't touch the settings at all.
  16. #16
    Quote Originally Posted by Paleogirl2003 View Post
    heard back from the extended controls developer - they just bought a nexus and are working on a fix
    tiny flashlight + led works great in the meantime, thanks for the suggestion
  17. #17
    zhanghaiping's Avatar
    Banned
    Posts
    Xeccon flashlight + led works great
  18. #18
    Tiny Flashlight and LED works perfectly. Switches light on and off quickly without delay.
  19. #19
    Tiny Flashlight/ led works great
  20. #20
    foug's Avatar
    Posts
    Global Posts
    45 Global Posts
    is there an app with brightness levels for the LED?
  21. #21
    Htc should have a built in app that can regulate the LED brightness level.
  22. #22
    GN flashlight by far... gives you a home screen widget / toggle
