1. niroowns's Avatar
    Anyone else notice that their phone doesn't rotate when moving from vertically to horizontally or vice versa for any of their home screens? I did check in settings that auto-rotate was checked off.
    It does seem to do it in youtube (to go to full screen)....
    Is this something that has been changed in ICS?
    12-15-2011 05:35 PM
  2. Phil Nickinson's Avatar
    Correct. The home screens don't rotate.
    12-15-2011 05:35 PM
  3. wheezy's Avatar
    Did home screens ever rotate?
    12-15-2011 05:40 PM
  4. pauldroidr2d2's Avatar
    No, the screen didn't rotate on Gingerbread either. The only time the home screens rotated was after I installed apps, like Launcher Pro.
    12-15-2011 05:43 PM
  5. Quills#WP's Avatar
    in my experience (which is limited), home only rotates with a non-stock launcher (e.g., adw).
    EDIT: pauldroidr2d2 beat me to it. ;-)
    12-15-2011 05:44 PM
  6. gabbott's Avatar
    I'm sure there will be custom ROMs to allow this ability. It rotates on some of the ICS ROMs I've installed on my NS4G.
    12-15-2011 06:40 PM
  7. iBowToAndroid's Avatar
    Don't need to be rooted; just need a non-stock launcher
    12-16-2011 12:38 AM
  8. ph0zz's Avatar
    I've found two apps that work for rotating the home screen. The simplest (free and no ads) is Rotation Locker by madmack (note that for Auto mode to work properly you need to long-press it). There's also the ad supported Screen Rotation Control by jubo co (no long press needed). Enjoy
    02-22-2013 05:20 AM
