Results 1 to 9 of 9
- 12-16-2011, 11:20 AM
Thread Author #1
Call Quality
Anybody else getting distortion, crackling, popping, occasional squeks while on a call? Its happening on calls from on cellular or land lines. It could be a VZN thing or tower. Im going for a drive and will see its a tower thing. Hopefully a tempory thing it makes my ear hurt!! Fyi..in cdma only mode.
Edit: no blue tooth and its only on received calls, outgoing are crystal clearLast edited by tlincoln; 12-16-2011 at 12:05 PM. Reason: no blue tooth and its only on received calls, outgoing are crystal clear!
- 12-16-2011, 11:30 AM #2
- 12-16-2011, 11:35 AM #3
Re: Call Quality
CDMA only here as well. Not having those issues at all. In fact the call quality is so good it sounds like the person is standing there talking to me. WAY better than my Incredible's call quality and it wasn't overly horrible.
The Storm has cleared to an Incredible day! I ate an IceCream Sandwhich. Still needed JellyBeans. ;-)NEXUS!!!!!! - 12-16-2011, 11:40 AM #4
Re: Call Quality
I was getting those yesterday - see Issues with Bluetooth and/or Jawbone Icon headset on Nexus. Since then, i've rebooted the phone, and done a hard reset of the headset, and somewhere in there, the pops and crackles seem to have gone away.
Are you using BT? wired headset? just the handset? - 12-16-2011, 12:04 PM
Thread Author #5
- 12-20-2011, 05:49 PM #6
Re: Call Quality
Yes! It seemed to happen on longer calls, around the 12 minute mark. It sounded like the person I was talking to was at WalMart scanning items there was so much beeping. I've made a few calls with my GNex before but none were as long as this one. How long were your calls?
- 12-22-2011, 12:40 AM #7
Re: Call Quality
Same thing here. On 3 calls in a row the phone would go crazy and start fluctuating the volume and finally degenerate into a bunch of loud squeals and pops. Tried another phone to the same number (while rebooting the SGN) with no problems. Then called back and same problem again. I hope it was a fluke!
- 12-22-2011, 12:48 AM #8
Re: Call Quality
I don't have a Galaxy Nexus but I do have a Samsung Droid Charge and it does that from time to time. I usually have to pull the phone from my ear as fast as I can and hang it up.
- 12-22-2011, 01:00 AM #9
Re: Call Quality
Both incoming and outgoing calls very poor quality - broken distorted voice - difficult to understand as if the call is hanging onto 0-1 Bar of reception. Signal strength is 100 to mostly 120dBm 99 asu
Will a hard reset improve the quality? If so, how do we do a hard reset?
Reply
