Results 1 to 4 of 4
- 12-16-2011, 05:21 PM
Thread Author #1
Slight Problem
Alright, so I decided to unlock my phone as soon as I got home from the store with it. The problem that I have encountered is not being able to connect to my computer. When I connect my phone VIA USB it only charges, and my computer wont detect it. It worked fine right up until I unlocked the bootloader and updated to 4.0.2. I wanted to try to restore to the factory image, but only have seen instructions on how to do that with a working USB connection.
Side note: I have several micro USB cables, and the only one that is working (at least for charging) is the one that came with the car charger. The other cables work as well, but only when the phone is powered off.
Any help would be appreciated!Last edited by x vortex x; 12-16-2011 at 05:33 PM.
- 12-16-2011, 05:39 PM #2
When you connect your phone to your pc, check your device manager and see if anything in that list has an exclamation point by it. Might need to install drivers again
Sent from the Nexus Galaxy far away - 12-16-2011, 05:42 PM #3
Re: Slight Problem
there are some really good guides to doing this, but I got the USB drivers from one of the steps > did you skip this part?
from: [GUIDE] How To Unlock Bootloader and Root Verizon Galaxy Nexus - 12-16-2011, 05:51 PM
Thread Author #4
Reply
