Results 1 to 8 of 8
    superlawyer15's Avatar
    Posts
    Global Posts
    798 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Default Battery Percentage Indicator
    Is there a way to show the battery percentage up top next to the battery icon?
    ..the icon itself doesnt give much information
  2. #2
    ManBearPig618's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Jelly Bean
    Default Re: Battery Percentage Indicator
    You'll need a widget instead....circle battery widget is beloved my many.
  3. #3
    Azaurath's Avatar
    Posts
    Global Posts
    69 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Alphaluulz CM9
    I was hoping this would finally be a stock option in ICS.
    But yea, a widget is your best bet, if you don't have root or want to.
  4. #4
    Mr. Poppalopolis's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Android Revolution Hd
    I haven't looked for long, but does anyone know of any mods that can add this? Battery percentage is one of the things I miss most about CM7. I've already flashed Android Revolution Hd, a launcher mod, and a power menu and auto brightness mod. Can't wait for CM9 to come out...
  5. #5
    sectachrome's Avatar
    Posts
    Global Posts
    41 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
  6. #6
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quote Originally Posted by sectachrome View Post
    I've seen a lot of these in other threads, but I'm looking for a replacement to the normal battery indicator. Something like the percentage option in Cyanogenmod or MIUI. Plus those have a constant ongoing notification.
    EDIT: http://forum.xda-developers.com/show....php?t=1375575
    That does exactly what I want. About to do a backup and try to install it. If I don't report back you should assume it worked.
  7. #7
    Snareman's Avatar
    Posts
    Global Posts
    1,947 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Stock
    Quote Originally Posted by Mr. Poppalopolis View Post
    EDIT: 1% Battery Mod for Deodexed ROM`s - Update 16.12. for ICL53F - xda-developers
    I don't think you can replace the stock battery icon unless you are rooted. I wanted the same thing.
  8. #8
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Quote Originally Posted by Snareman View Post
    You're correct you can not. I just forgot not all people root, but hopefully this helps anyone who is rooted and looking for something to do this. It also optionally adds a search button which I find really useful.
