Results 1 to 15 of 15
Like Tree2Likes
  • 1 Post By Andrew Ruffolo
  • 1 Post By jerrod6
    Default How do I get my PC to recognize the Nexus as a drive?
    Hey guys...I can get the computer to link to the Nexus and transfer files such as mp3 for ringtones but my issue is getting the PC to recognize the phone as a drive instead of portable media device. The reason I need this is I use an android app called Pocket Dairy for work...it connect to the computer via micro usb cable and then downloads the info to the phone that I need for it to work. Have the app installed but as long as it can not find the phone as a drive it won't transfer the info. Any way to get this to happen?
  2. #2
    dookie.'s Avatar
    Posts
    Global Posts
    150 Global Posts
    Default Re: How do I get my PC to recognize the Nexus as a drive?
    Sorry, no. MTP is the only communications protocol supported via USB.
    Thanks...so only android phones with sd cards are able to do this?
  4. #4
    radgatt's Avatar
    Posts
    Global Posts
    576 Global Posts
    ROM
    Stock
    No mass storage mode
  5. #5
    Andrew Ruffolo's Avatar
    Posts
    Global Posts
    3,815 Global Posts
    ROM
    Stock
    Quote Originally Posted by bbhybridchris View Post
    Even tablets with SD Cards still show up only as MTP mode. you can still drag and drop the same way. The benefit is you can transfer files with the SD card in without affecting running apps installed to the external storage. I'm probably one of the few in favor of it. If it bugs you enough, you could just use an FTP through wifi app and transfer files wireless through a web browser.
    cadman likes this.
  6. #6
    How can I sync music files from my PC to GN? I don't want to use google music or such. Just a sync from certain folders on my PC to the GN.
  7. #7
    I used Media Monkey to sync music files and playlists seamlessly..
    HTC Droid Incredible and loving it...
  8. #8
    I haven't tried it yet but I found a shareware product called "ptpdrive" which sounds like it would work.
  9. #9
    Montclair's Avatar
    Posts
    ROM
    Rooted/Stock
    you need the newest drivers.search on androidcentral for help. Worked for me.
  10. #10
    cadman's Avatar
    Resident Ringtone Maker
    Posts
    Global Posts
    6,822 Global Posts
    ROM
    BB JB
    What about the app Jerry suggested, Wifi File Manager?
    How to install an Invisible Shield
    3rd GN 2-29-12
    2nd GN 1-1-12
    1st GN 12-17-11
  11. #11
    Masheen's Avatar
    Android OG
    Posts
    ROM
    Redemption//Franco.Kernel
    I'm pretty sure this is the driver that you need to install. If that does not work then go into your computer's device manager and find the yellow exclamation mark next to the galaxy nexus driver. Right click and manually update the driver; one of these two methods should work, if not both.
    usb_driver.zip
  12. #12
    Quote Originally Posted by tony bag o donuts View Post
    I don't know about the syncing thing but this app that Jerry suggested seems to work well for me. After installing you start the app...it gives you the Wifi address to type into your browser and BANG...the directories and files on your phone are presented in your browser. You can open the folders to view files, you can upload data from your PC to your selected folder....
    I'm a happy camper with this.
    Also my windows 7 system automatically downloaded the newest Samsung drivers when I connected the phone and I can copy and paste files using my USB connection. The only thing I noticed with this method is that the file explorer will recognize the phone as an external device instead of a drive, but you can still open the contents of the device to copy files into a phone folder. Using Windows 7 file explorer, I need to select the files to copy and then drop them onto the unopened destination folder. If I open the destination folder in file explorer the copy doesn't seem to work.... Not much of a problem but something I used to be able to do with a phone with SD card and running Android 2.2
    With Wifi File Manager...none of this is even necessary....just install the app, use it, and it's done.
    Seems like it is a Samsung Kies alternative that works well. Never used Kies so this app might even be better!
    Thanks Jerry!
    Thanked by:
    cadman
    cadman likes this.
  13. #13
    cadman's Avatar
    Posts
    Global Posts
    6,822 Global Posts
    ROM
    BB JB
    Quote Originally Posted by jerrod6 View Post
    Thanks Jerry!
    and this can be done from any pc? I want to send a few timesheets to my phone from work not using email and didn't want dropbox installed.
    3rd GN 2-29-12
    2nd GN 1-1-12
    1st GN 12-17-11
  14. #14
    You can also use Winamp to wireless sync through WiFi. There's a winamp app in the market and you'll have to download the lastest version of winamp for windows. I used it previously on my EVO 3D and it works for my Nexus as well.
  15. #15
    DaPoets's Avatar
    Posts
    ROM
    4.0.3 Codename 1.5.0
    Quote Originally Posted by CarSalesman View Post
    But that's what Google Music does... syncs music from what ever folders you tell it to...
    DaPoets
    ~ Galaxy Nexus LTE Codename Android ROM 1.6 (ICS 4.0.3)
    ~ Motorola Xoom LTE Codename Android ROM 1.5.5 (ICS 4.0.3)
    ~ Droid Charge as 24/7 4G Unlimited Tether Bot on Stock
    G1000 -> PPC6600 -> PPC6700 -> OG Droid -> Galaxy S Fascinate -> Pure Bliss
