1. Scottee28's Avatar
    Has anyone noticed chirping noises or popping type noises during a phone call? I have the weaker 4G signal inside my apartment but believe I was on 3G during the call. Ever so often I would get this chirp, pop noise during the call. I had the sound+ app installed, but I uninstalled to see if it was the cause.
    12-18-2011 11:00 PM
  2. djarmin's Avatar
    Yes. But my last call was the first time I had this happen
    Sent from my Galaxy Nexus
    12-18-2011 11:04 PM
  3. EzDoesItTLC's Avatar
    I installed Skype on my Galaxy Nexus the other day and every call has chirped the entire time connected. Very irritating. Did you find a solution?
    03-12-2012 06:57 PM
  4. tlincoln's Avatar
    i believe its the NFC chip/antenna, turn off NFC and do a battery pull, it fixed mine.
    03-12-2012 08:38 PM
  5. anthony81586's Avatar
    I never noticed it, my call just drops hahaha.
    03-13-2012 05:17 PM
