1. wallyweaver's Avatar
    i NEED SOME SERIOUS HELP!!!
    I don't know what happened to my Nexus. Before I installed google wallet, everything was fine in Nexusville. After the install about an hour later I powered my phone down. I was trying to mod the verizon case with the stand on it to fit the extended battery. I AM NOW STUCK IN A NEVER ENDING CYCLE OF REBOOTS!!!!!!! It wont stop, gets about half way through the startup and then reboots again. WHAT DO I DO????? I am freaking out. I tried to go back into the bootloader and tinker a little, but there is not much to do there yet without being rooted. Can someone PLEASE help?
    12-18-2011 11:02 PM
  2. hyperdude's Avatar
    Pull the battery out, let it sit a few minutes, put the battery back in and try booting it up again. If that fails, you could boot into recovery and do a data wipe from there - that should presumably get rid of Google Wallet (which probably is what's causing the issue) but it is a factory reset...
    12-18-2011 11:06 PM
  3. wallyweaver's Avatar
    It wont boot into recovery. Get a red exclamation point. Battery pull to no avail.
    12-18-2011 11:10 PM
  4. hyperdude's Avatar
    Well, you could reboot into the bootloader and unlock it, since that will do a factory reset.
    12-18-2011 11:14 PM
  5. wallyweaver's Avatar
    its already unlocked
    12-18-2011 11:17 PM
  6. hyperdude's Avatar
    You could download the factory images from Google and flash them.
    http://www.google.com/url?sa=D&q=htt...iI9yTxKdUyW1tA
    wpbfjr likes this.
    12-18-2011 11:18 PM
  7. wallyweaver's Avatar
    how do i get them on the phone, i cant connect it to my computer
    12-18-2011 11:30 PM
  8. hyperdude's Avatar
    Not my area of expertise, but I know you connect the phone to the computer in bootloader mode, and do something like adb flash system.img
    If you physically can't connect it to the computer, then I don't know what help that will offer.
    12-18-2011 11:39 PM
