WIFI Speed bug?
xweb10
556
Please let me know if this issue is persistent for any of you.
WIFI ON, BT OFF: I get ~16MB down using SpeedTest App (close to expected speed).
WIFI ON, BT ON: I get ~3MB down using SpeedTest App.
Bluetooth seems to slow my WIFI data connection.
Also of note, when BT is on, I do not connect to my Verizon Network Extender properly.
Bad phone, or bug?
Thx. Did your Bluetooth have something to connect to, or did you just turn it on?
I swapped my phone out for a new one and the bug persists.
If you are connected to a WIFI network and a BlueTooth device, the WIFI data speeds slow down.
r3dpuk3
