- 12-19-2011, 06:59 PM
Thread Author #1
Step by step Light Flow instuctions
Does anyone have any?
I have searched all over and everyone says this app is the bees knees. But for the life of my I cannot get it to work with text messages. (It appears to be working with Gmail). It has to be something simple and I feel dumber than a sack of hammers right now.
I had Handcent and then read that someone had better luck with Go SMS pro so I removed Handcent in favor of the latter. I did buy the pro version of Light Flow as it appeared to have more granular control.
What I have checked:
-Phone
Display > Settings > Pulse Notification Light > Checked
-Light Flow Pro
Enable Light Flow > Checked
Direct Mode > Unchecked
Run in Foreground > Checked
(rest is stock)
-Go SMS Pro
Notification Settings > Default Notification settings > LED settings > Blink LED > Checked
This should be it, right? I'm tempted to just wipe the whole phone and start over but I'm sure I am missing something... - 12-19-2011, 07:02 PM #2
Re: Step by step Light Flow instuctions
I can't seem to get it to work with charging.
- 12-19-2011, 07:02 PM #3
I haven't downloaded this app at all, but I can't help but wonder, if the phone has the LED, and most of the apps it should work with have options for it, why doesn't it work by default? I figured, like most phones, it would light up while charging, but it didn't. It also doesn't light up when I get any notifications. So why is it that a separate app is needed to make it work?
- 12-19-2011, 07:03 PM #4
- 12-19-2011, 07:55 PM #5
This is a hard app to set up because there are soo many options
I had to email the developer a few times for help and he was kind enough to respond
...but let me tell you once you get it up and running correctly its amazzzzing!!
make sure when you go into notifications and you select something, for example SMS
you have both the entire notification checked on and the light notification for that particular notification checked on
there are a lot of other types of notifications other than light such as vibrate and sound, those have to be checked on/off individually like the light notification - 12-19-2011, 08:35 PM #6
- 12-19-2011, 08:43 PM #7
- 12-19-2011, 08:58 PM #8
Yeah, I thought it was pretty straightforward.
Tasker, on the other hand, is the one that kills me... - 12-19-2011, 09:21 PM #9
Tasker is indeed an app that requires serious learning and understanding...but that is the boon that comes with an application that gives you incredible power over your phone. Light Flow is actually rather simple, just flexible. If it had less flexibility, people would complain that it has no practical use and is too dull
Sent from my Galaxy Nexus using Tapatalk - 12-20-2011, 07:14 AM #10
- 12-20-2011, 08:23 AM #11
- 12-20-2011, 08:53 AM #12
- 12-20-2011, 11:40 AM #13
- 12-20-2011, 11:48 AM #14
Haven't been able to really test it out, but am I the only one that had stability problems setting the app up? Every time I'd go into one of the notifications to edit the details, when I backed out, I'd get a blank screen, even if I backed to the main menu of the app then clicked "Notifications", it would still be blank. I'd have to back out of the app completely, then reopen it, in order to edit each one. About halfway through this process, my phone rebooted by itself.
- 12-20-2011, 11:50 AM #15
- 12-20-2011, 11:51 AM #16
This happens to me randomly every once in awhile too. I get my notification sound with a peice of my ringtone thrown in with it. I also get sounds and ringtones randomly with no reason behind it. the phone will ring but there is no call or text. Happened 2 or 3 times so not a huge problem but it has to be the app doing it cause I never noticed it before I got Lightflow. It always happens when I am away from my phone so I have not actually been able to see what is on the screen when it happens. By the time I get to my phone or my girlfriend tells me it rang I unlock the screen to find nothing, no missed call or text.
I can try uninstalling and re-installing but haven't yet or maybe I missed a setting for an app that is alerting Lightflow but I don't have set to alert me on the phone itself or something?Galaxy Nexus!!! Finally Mine
- 12-20-2011, 11:55 AM #17
- 12-20-2011, 02:31 PM #18
I got this today and it is working great, haven't played to much with the settings.
it says with root it can control the LED "s6e8aa0" is that the camera flash? - 12-20-2011, 04:23 PM #19
I may be stating the obvious for some...but...lightflow only lights up the LED when the screen is off.
- 12-20-2011, 06:16 PM
Thread Author #20
Thanks for the tip!
I spent 6 minutes and it all became clear!
But seriously I unchecked everything I had checked - then rechecked it and lo and behold it works! Will it always take precedence over other apps? i.e. Can I turn notifications off in Go SMS Pro or do they need to stay on? Just curious for curiosity's sake. - 12-20-2011, 08:48 PM #21
I disabled the app all together and the double notifications and phantom notifications stopped! I'm probably going to keep it off until the app is patched.
Sucks... cause I really liked how this app allowed me to make the phone vibrate longer. I was no longer missing notifications when the phone was in my pocket. - 12-21-2011, 04:46 PM #22
You aren't the only one. I have the exact same symptoms. Can't get the charging notification to work and then have the black screen of death. I was mad because my last backup was many modifications ago. Fortunately, the screen came back up.
I have uninstalled and staying away until it becomes more stable on the Galaxy Nexus. - 12-22-2011, 07:49 AM #23
This is the only thing that's disappointing to me. It would be perfect if it did work with the screen on.
That and I haven't gotten it to cycle the notifications like it claims to be able to do. Like when you have a text and an email. You have blue for text, red for email. And it will blink blue then red. I have all priorities set to 1, so idk why it just keeps blinking the latest notification.Droid Charge - 12-22-2011, 09:22 AM #24
for those of you getting double notifications:
go into the app you are getting double from (messaging, gmail, ...) and turn it's notification tone to silent, and vibrate to never.
you're getting double because messaging is giving a notification, and light flow is giving a notification at the same time. - 12-22-2011, 09:45 AM #25
Reply
