- 12-20-2011, 05:22 PM
Thread Author #1
Battery Life Fix!
Disable Google Plus! I have had it like this for a day now,and my battery life has increased 4-5 hours! Believe me or not I honestly don't care. Setting-Apps-All-Google Plus-Disable-???-PROFIT!
Sent from my Galaxy Nexus using TapatalkThanked by 3: - 12-20-2011, 05:25 PM #2
- 12-20-2011, 05:26 PM
Thread Author #3
- 12-20-2011, 05:29 PM #4
Re: Battery Life Fix!
I wonder if just unselecting the sync options for it would do the same.
- 12-20-2011, 05:29 PM #5
Did you have the Android OS eating most of your battery or was yours screen? My screen is what is killing mine hard. Leaving it on for like 10 minutes kills 10% of the battery.
- 12-20-2011, 05:32 PM
Thread Author #6
- 12-20-2011, 05:33 PM #7
I get 10 hours no problem with two emails syncing all the time. 40% screen use accordingly to the battery
Sent from my Galaxy Nexus using Tapatalk - 12-20-2011, 05:33 PM #8
- 12-20-2011, 05:50 PM #9
- 12-20-2011, 05:51 PM #10
Yea, this has actually been an ongoing thing across all Android devices with Google Plus install. Most have found that after they installed G+. their battery lasted shorted then their norm.
So many phones, so little time. - 12-20-2011, 05:54 PM #11
I've been getting great battery life while still using Google+. I did deny instant upload though and if you choose to upload all your pictures it will use a lot of memory and power uploading.
If you think someone is being rude its probably because you miss understood them. - 12-20-2011, 06:02 PM #12
- 12-20-2011, 06:14 PM #13
By the way, you can just disable background data instead of the entire app. First I set a ridiculous data cap (you must set a data limit before you can disable background data for an individual app). Then I check the box to disable background data for G+.
*customized tapatalk signature*Thanked by 3: - 12-20-2011, 06:14 PM #14
what if you dont use Google+? does disabling make a difference?
Sent from my Galaxy Nexus using Tapatalk - 12-20-2011, 06:31 PM #15
If this is really the case, anyone who can confirn this please let google know so we can get it fixed without having to disable. Becauze i use Google + a lot as well.
- 12-20-2011, 06:34 PM #16
I'm assuming that if you dont have a G+ account then there would be nothing for it to sync to. So disabling it would make no difference. Unless G+ app has a software issue and its leaking mem/ram causing a battery drain, but i doubt that.
- 12-20-2011, 08:08 PM #17
Yeah me too. I'll deal with it for now. I'm thinking its more of a problem with G+ than ICS. Google probably needs to tweak the code in the G+ app and it'll get better. But until then I think a good first step for us would be disabling background data for G+. I think the drain comes from all of the pictures that people in your circles post on G+ that are syncing in the background all the time. I don't think you'll get push notifications if you disable background data though.
- 12-20-2011, 08:14 PM #18
I don't use it and don't see a way to disable it. When I go into settings and click on Google+ icon it asks me which account I'd like to use and I have it checked not to automatically upload. Would this be sufficent becasue I tried to follow the OPs Settings-Apps- All(and don't see this)
- 12-20-2011, 08:17 PM
Thread Author #19
- 12-20-2011, 08:33 PM #20
- 12-20-2011, 08:41 PM #21
I don't use google plus "yet" I'm gonna try this and see how mine acts...I have the extended Battery and I haven't had a chance to compare battery life to the standard battery yet but hopefully I can squeeze a little more juice out of my Battery life...
- 12-20-2011, 09:05 PM #22
- 12-20-2011, 09:10 PM
Thread Author #23
- 12-21-2011, 04:33 AM #24Motorola Razr Maxx
- 12-21-2011, 04:58 AM #25Follow me @ItzAstonish
Reply
