Is there an app or widget out there that will give you detailed battery usage for your applications and/or widgets? I'm suddenly having high battery drain from the OS and not sure what program is causing this. Thanks for your help.
Do you mean as opposed to the standard battery tab in the settings? This shows you how much of your battery is used by each individual app as well as how much is used for the screen etc. You don't need any extra app or widget.
