03-08-2012 01:24 AM
60 123
tools
  1. kca2000's Avatar
    First let me get this out the way, This is not another thread bashing the Gnex for signal issues. Im well aware that the phone is not the issue in my case. This phone is awesome, but just looking for opinions on fixing this problem.
    Just a little back round of the issue. After im done with my day i usually go down to my basement to my "Man cave" to relax and do any work left over since my office is down there as well. When i had my droid 1 i was able to keep 1 bar 99% of the time, so i never had an issue holding a call. 1 bar on Verizons network seems to be plenty.
    But now that i have the Gnex it struggles to keep any bars. Im usually pinned at -120 dbm / 99 asu, No bars shown. I assume this is not good? The phone is reporting its without signal 80% of the time im in the basement, Also not ideal. So what i am asking here is will a Verizon network extender help here? Weak signal in my house has always been an issue, but its never really been a problem till now.
    I did some research and found this model on ebay.
    NEW VERIZON WIRELESS SAMSUNG NETWORK EXTENDER SCS-26UC4 | eBay
    I understand this is the older non 3g model, my question is will this work to give me a better call signal?
    I dont care about 3g data in my house, my wifi is much more reliable and faster. But do i need the 3g model to accomplish this or will the older model suit my needs?
    Any help is appreciated, Also if anyone actually owns either the 3g or older model please chime in with your experiences. If anyone has bought one on ebay like i listed any feed back would be great as well on the purchase. Do i need to place this thing near a window? Or will next to my router in the center of the basement suffice?
    Thanks to all in advance.
    12-22-2011 06:55 AM
  2. rjack22's Avatar
    I have the newer model network extender. It works great! I used to get only 2 bars inside my house and sometimes had dropped calls unless I stood near a window. Now I have full bars. I think a network extender would be a great solution for your basement.
    You do have to put the antenna near a window and at the same time be able to plug the extender into your router. You may have to work that out.
    yoyoche likes this.
    12-22-2011 07:39 AM
  3. kca2000's Avatar
    Did you get this from Verizon i assume? 249$ is a little steep for me, Especially if i can get by with the older model off of ebay for 100$ and have that solve just my voice signal problems. But if Voice travels over 3G i am not sure the older model will be sufficient?
    12-22-2011 08:02 AM
  4. greydarrah's Avatar
    I'm in your same position with the man cave in the basement and 1 bar of signal on my X. 2 years ago I bought Verizon's network extender and the older. non 3g version gave me a full 4 bars in my basement (the network extender was one floor up). I did upgrade to the 3g version, but the call signal strength is the same. It's well worth having (old or new version). I used to have to run up the stairs or out into the back yard if I got a call. Now I can sit comfortably and talk all I want.
    kca2000 likes this.
    12-22-2011 08:35 AM
  5. dookie.'s Avatar
    I've been using a network extender for several years... first the 1x version, and as of this spring a 3g one.
    Signal strength has always been an issue here as well, and at the advice of a VZW rep at a corporate store, I called 611 to complain (and mentioned that I was really hoping to kill my land line and switch to an unlimited VZW plan).
    They said I was in a known low-signal area, rolled a truck to do a site survey (confirmed... surprise!), and then GAVE me the extender for free. When the 1x crapped out, they happily swapped it for the latest 3g version also at no cost. I do not believe the 4G extender has been released.
    The claimed coverage is 5k sqft, and I get full bars nearly everywhere in my house (2 floors @ 2k sqft each, standard wood framing w/sheet rock). My nearest neighbor has seen an improvement as well, so I think the reach must be pretty good. You can limit the devices that the extender will allow to connect, should you want to... though I don't. (I live in the sticks and really only have one neighbor in range, who I am happy to do the favor for.)
    12-22-2011 08:41 AM
  6. dookie.'s Avatar
    Oh... voice will work fine on 1x. But if you see any 3g signal, it will try to use that. So you may have to disable 3g on the phone when at home.
    12-22-2011 08:43 AM
  7. dookie.'s Avatar
    Oh... and the 3g extender is nice for visitors. Don't have to bother putting them on your wifi.
    12-22-2011 08:45 AM
  8. ctechnow's Avatar
    i'm thinking about getting this as well.. I want Vzw to give me it for free like ATT did..
    12-22-2011 08:52 AM
  9. MrVeda's Avatar
    I thought this model NEW VERIZON WIRELESS SAMSUNG NETWORK EXTENDER SCS-26UC4
    was the latest 3G extender? I was about to order this and now looking for confirmation as my new GN is also unusable at home.
    Can anyone confirm the latest model number with 3 g?
    12-22-2011 08:52 AM
  10. Cyber Warrior's Avatar
    I have the 3G network extender... works great... 3-4 bars in my home where I use to have none. It doesn't run off of Verizon's towers. Its hooked up to your cable modem which then sends the signal. Only problem is that my GNex isn't working with the extender... I'm getting maybe 1-2 bars with the data cutting in and out. I'm assuming that Verizon will eventually get this sorted out... for now its back to using wifi.
    12-22-2011 09:05 AM
  11. greydarrah's Avatar
    That's odd because with my 3g extender, I definitely get 4 bars on my GN where I would only have 1. I winder why it's not hitting yours that way. By the way, I had 4 bars on both the stock radio as well as the latest leaked radio.
    12-22-2011 09:09 AM
  12. joggy's Avatar
    I can confirm that the original, non 3G, VZ Network Extender will work for improving call quality/reception on the GNex.
    When I make calls using the extender I have never had a dropped call. Without the extender I can barely stay connected in a call.
    Go for it!
    12-22-2011 09:10 AM
  13. marcw's Avatar
    what does the 3g or 4g do for you if your phone is connected to your home wifi?
    12-22-2011 09:10 AM
  14. Cyber Warrior's Avatar
    I bought mine from Verizon three months ago... its the newest one. It looks exactly like the one in the picture on eBay except my model number is SCS-2U01... so not too sure.
    12-22-2011 09:15 AM
  15. MazoMark's Avatar
    Oh... and the 3g extender is nice for visitors. Don't have to bother putting them on your wife.
    Might want to proofread that message!
    12-22-2011 09:18 AM
  16. Cyber Warrior's Avatar
    LOL
    12-22-2011 09:21 AM
  17. dookie.'s Avatar
    thanks tapatalk / swiftkey for that autocorrect laugh...
    in any case, i'm using the scs-2u01 and it works great with the nexus. the 3g extenders (by default) allow the first 5 devices they see to connect (just 3 for 1x)...after that, talk to the hand.
    if you're having connection issues, it's likely that your friends/neighbors phones have associated and burned up all your open slots. if you think you're having connection problems, reboot the extender to clear the list, then use myVZW to limit the devices that can connect to just yours.
    Cyber Warrior likes this.
    12-22-2011 09:35 AM
  18. Cyber Warrior's Avatar
    Thanks... I think that's exactly what's happening. Now that I think of it... I just had two new tenants move in downstairs about the same exact time I bought the phone. I'm pretty sure they have Verizon... I'm gonna check myVZW right now.
    12-22-2011 09:46 AM
  19. wunderkinder's Avatar
    I have a 3G network extender from Verizon, and I also have a Nexus. Prior to the Nexus I had two different RAZRs, both of which got returned due to continual issues with the phones dropping data and missing incoming calls. Sadly, the Nexus is encountering the exact same issues. I've gone around and around with VZW to try and fix the issue, and nothing we have tried has fixed the problem. Prior to the RAZRs, I had an OG Droid that worked flawlessly on the 3G Network Extender for several months.
    To get around the dropped 3G data issues, I started leaving wifi enabled on my Nexus all the time. This didn't drain the battery as fast as I feared, so I can live with this solution. The bigger issue is that I keep missing incoming calls on my Nexus. The phone will not even ring (sitting 4 feet from the Network Extender), which is really starting to annoy me and my clients who can't reach me. I am personally convinced that there is an issue with the Verizon 3G Network Extender and 4G phones. I've read that people had similar problems with the Thunderbolt and the Bionic. Well, add the RAZR and the Nexus to that list.
    12-22-2011 11:03 AM
  20. st0ic_1's Avatar
    Question; what does connecting the extender to a router(no modem in my situation) have to do with boosting the signal?
    12-22-2011 11:17 AM
  21. wunderkinder's Avatar
    It doesn't boost the signal, it creates its own. Think of it as a mini cell tower in your home.
    12-22-2011 11:18 AM
  22. Cyber Warrior's Avatar
    Just got off the phone with Verizon... the network manager in MyVerizon is having problems and will be fixed by January 10th so I had her manually add my numbers to the white list.. anyways, we tried troubleshooting the problem and there was no fix so she put in a support ticket to have the techs take a look into the matter. I'm getting full bars for voice calls but my 3G data connection is constantly dropping in and out to where it's unusable.
    Never had this problem with my Thunderbolt... so it's either I use the extender and get full bars for voice calls and no data connection or I use wifi and get 0 bars for voice calls and still have a data connection.
    12-22-2011 11:19 AM
  23. exarkun's Avatar
    I have poor signal issues at home (all providers) and use VOIP/SIP on my wireless. I have my own asterisk box, however if you're not up for that you could get a free pbxes.org account and use that.
    12-22-2011 11:57 AM
  24. wunderkinder's Avatar
    I'm already in $300 for the Network Extender and another $300 for the phone. If the Nexus doesn't start working within the next few days, I'll probably revert to my OG Droid (again).
    12-22-2011 12:01 PM
  25. ElusiveAura29's Avatar
    I had 0 bars of signal at my house with the GNex where with the iphone4 I had 2 bars. I got verizon to knock off $100 off the network extender from $250 to $150. I had to speak to a level2 tech to get that price, only they can do that supposedly. Told them I wasn't paying $250 for service I should already be receiving.
    Long story short, my signal went from 0 to full LOL. I love the extender. Have the gps sitting in my window in my bedroom and living room still get full signal. Works great.
    kca2000 likes this.
    12-22-2011 01:55 PM
60 123
