1. miamifin33's Avatar
    Hi All,
    I need your help figuring out a recurring message I am receiving on my new Galaxy Nexus. It comes up as a plus sign in my notification bar and reads *(Gift Pending)* You Could Be Today's Christmas Winner>. I have attached a screen shot of what I am seeing.
    Any ideas on how to get these messages to stop?
    Thank you!
    12-22-2011 01:22 PM
  2. tntdroid's Avatar
    junk from a app that's installed. Nothing to do with ics or the nexus. Look over the last apps you installed and when it started.
    miamifin33 likes this.
    12-22-2011 01:32 PM
  3. dubge's Avatar
    Here is another post talking about it
    Random advertismets via notification bar
    I didn't read much of it but it sounds like what you are experiencing
    12-22-2011 01:35 PM
  4. SAENZ_SCENE's Avatar
    Download an app called addons detector. It will scan and show you what app is causing this issue. Airpush detector will work to.
    12-22-2011 01:35 PM
  5. jayhawkfan18's Avatar
    Yes do what ^^ said. AirPush Detector told me it was my date widget. (ExtDateWidget)
    12-22-2011 01:42 PM
  6. miamifin33's Avatar
    You guys are great. Thank you so much for the quick replies. I will look into this shortly and report back with my findings.
    12-22-2011 01:54 PM
  7. DaPoets's Avatar
    That's from the Christmas Tree HD live wallpaper app I believe. I had that popping up when I installed it and when I uninstalled it the darn thing never came up again.
    12-22-2011 02:48 PM
  8. miamifin33's Avatar
    Turns out it was an mp3 downloader. Airpush detected it.
    12-22-2011 04:55 PM
  9. ccm435's Avatar
    This started happening to me a little about a week or so ago, and I couldn't figure it out. Thanks to a couple suggested apps that show what other apps do I found out is was an app I don't even use called BloatFreeze. Removed it and no more Gift Pending malware ads! Such lameness.
    -cm-
    01-01-2012 06:52 PM
  10. jayhawkfan18's Avatar
    I just realized today that it will give you a website to go to so that you can "opt-out" of receiving ads in your notification bar. I did it today so we will see if it works.
    01-03-2012 08:14 PM
