- 12-22-2011, 02:08 PM
Thread Author #1
Lost 40% battery in two hours with light use? WOW
Didn't know the battery will be this poor. Woke up at 12pm with 90% battery. Made a few text. Made one phone call. No browsing. At 2PM, battery is now down to 50%! LOLOL I don't think there will be a fix for this.
My settings
-Brightness at 25%
-Wifi on
-Mobile data off
-GPS locations turned off
-background data restricted
-all apps stopped
- G+ disabled
-All sync disabled - 12-22-2011, 02:14 PM #2
- 12-22-2011, 02:14 PM #3
Re: Lost 40% battery in two hours with light use? WOW
Are you running a task killer?
Off topic: Why don't you guys charge your phone while you sleep? You're not the only one, and its very odd. - 12-22-2011, 02:15 PM #4
That is just crazy..........you woke up at noon!!!!
Samsung Galaxy Note 2 - 12-22-2011, 02:24 PM #5
I am betting its the damn screen, it's just freakin ridiculous. You can't use the damn thing unless you are charging....
- 12-22-2011, 02:25 PM #6
- 12-22-2011, 02:29 PM #7
- 12-22-2011, 02:34 PM #8
- 12-22-2011, 02:37 PM #9
Verizon Galaxy Nexus | Bugless Beast 4.1.1
If you appreciate something I post, like it and/or give thanks! - 12-22-2011, 02:40 PM #10
- 12-22-2011, 07:32 PM #11
since i got it dec 15 mine was about 8-9 hours. weird that yesterday i had to charge it twice with no use.. it would eat up my battery in 3-4 hours.. i was pissed off.. I love this phone but something has to be done quick. I told my wife if it doesnt get fixed by jan 15, we are returning(really dont wanna do it).. played with Rezound and its actually a really nice device.. charged it at 8 pm yesterday and I AM SHOCKED.. its been 23 and a 1/2 hours and I still have 34% left..
- 12-22-2011, 07:50 PM #12
- 12-22-2011, 07:53 PM #13
- 12-22-2011, 08:28 PM #14
Not to alarm the OP, but it's possible you might just have a bad unit. I have syncing off, NFC off, auto brightness, I leave 4G on, and I use Juice Defender (though I don't know how much that actually helps); in about four hours, with 30-45 minutes of that spent browsing, e-mail checking, texting, and making a call, I had about 85% left.
- 12-22-2011, 08:30 PM #15
- 12-22-2011, 08:42 PM #16
- 12-22-2011, 08:45 PM #17
My battery life got worse daily, I exchanged my out today for a new one, moreso because of signal issues. I was getting about 10 hours initially with light to moderate usage, then it decreased to 3 -5 hours.
fillyo
Samsung Galaxy Tab 2 on CM9 - 12-22-2011, 08:51 PM #18
I am running over 14 hours since unplugged and still have over 60% left.. fully stock screen brightness around 75% and light use for the day.. texting and calls mainly. So it has to be certain phones or batteries because this is the best phone i have used so far in every category.
~FTG13 - 12-22-2011, 09:28 PM #19
- 12-22-2011, 09:30 PM #20
- 12-22-2011, 09:43 PM #21
- 12-23-2011, 01:26 AM #22
I was experiencing the same issue, with the extended battery installed! My phone would be at about 10% battery left after 6hours of light use.
I highly customized it with various widgets, keyboards, and many other apps.. My son's, was at 36% after 10hours with the standard battery, but his was configured minimally from stock ICS.
I just wiped my phone, just putting on MUST HAVE apps and will monitor, no widgets, minimal apps and see if the issue is the phone or apps.There is no place like 127.0.0.1
- 12-23-2011, 02:32 AM #23
Something's not right. Today, I played a game with GN for the STRAIGHT 5 HOURS AND 35 MINUTES until the battery reached 10%!!! According to your statement, your GN with only a few textings consume pretty much the same amount (40%) of battery as mine which was completely on all the way in two hours???
My GN was at auto brightness, Wifi on and connected, GPS on, NFC on. The game was not using internet data much. Even though the game was not using much data, screen was on straight 5 hours and 35 minutes with extensive CPU usage.
It is pretty much basic, when you ask for answer for this kind of question, that you need to capture your battery history screenshot and attach it on your post. It will tell us a lot about what's going on in your GN. - 12-23-2011, 05:46 AM #24
Same issues here. The batter gets drained way too quickly. Even on idle. Not only that but it takes way too long to recharge. I've calculated that it takes about 1 minute per percent to recharge. That is way too long. I came from a Moto Droid 1 and it would do it in half the time if not, better. I'll mess with the setting to make it more efficient but the batter issue needs to be resolved.
- 12-23-2011, 06:14 AM #25
I got 7 hours last night out of the extended battery.......with 5 hours and 10 minutes of screen on time. I streamed a netflix movie, played GTAIII for a long time, streamed music, and surfed the net like it was my job. I thought that was reasonable battery life for that much abuse.
Reply
