1. MrLorence's Avatar
    As the title says...shouldn't it be blue with the 3g thing next to it?
    On my X it was...
    Anyone else having this "issue" if it even is one?
    12-23-2011 12:05 AM
  2. Channan's Avatar
    It means you've lost connection to Google services. When you answer a call on 3G (no 4G or Wi-Fi) you lose data therefore access to their services.
    12-23-2011 12:07 AM
  3. MrLorence's Avatar
    but its still letting me make calls...
    12-23-2011 12:21 AM
  4. DaPoets's Avatar
    you don't have to be connected to google to make and receive calls.
    12-23-2011 12:23 AM
  5. chriskidwell's Avatar
    Voice and data are seperate. You dont need data access to make phone calls.
    12-23-2011 12:23 AM
  6. MrLorence's Avatar
    Right, but its not normal...is it?
    12-23-2011 12:29 AM
  7. Sentrix's Avatar
    It's normal. The GN does not have SVDO like, for example, the Thunderbolt or Rezound. It cannot do voice and data simultaneously over 3G. So in areas without LTE, your data will drop, just like all other 3G phones.
    12-23-2011 12:34 AM
  8. jphillips1963's Avatar
    The thing is on the GN (I had) When I was on 4g and made a call the phone would drop data all together, This isn't suppose to happen thats one of the biggies for Verizon now is being able to have access to data while on a phone call. I know my Droid Charge would have data connection and be able to talk at same time if it was in the 4g network.
    Sorry to say but I just wasn't going to wait this one out, I got burned when buying my xoom tablet on launch day with promises of upgrades and all within 90 day that didn't happen for nearly 7 month later, So I swapped out today for the Rezound and I'm happy I have 4g in areas I couldn't get 3g with the GN the dBm levels are ranging from 24-36dBm lower on the rezound than the GN My speed test results are blowing my mind my highest so far on the Rezound is 55.19 Mbps DL and 19.92 Mbps UL My lowest numbers are 18.26 DL and 11.66 UL I think the highest I ever got if my memory serves correct on the GN was 12-13 DL and 4-5 UL
    Sorry guys but Sammy and Verizon and Google has a lot of work ahead of them to fix whats suppose to be the Flagship of all phones to come to par with whats avail. now. Yes it has Ice Cream but what good is that if the phone itself doesn't function as designed. Heck my Charge outperformed the GN in same areas and it wasn't anything to brag about I guarantee that.
    I really wanted the GN to be my phone to show off and brag about but it is what it is.
    James
    12-23-2011 12:42 AM
  9. MrLorence's Avatar
    But I'll still get texts and emails during calls and that requires data, no?
    12-23-2011 12:43 AM
  10. jphillips1963's Avatar
    No it doesn't those are two seperate features in the phones, Your other phones still collected text message while on a phone call as well. I'm unaware though you are able to receive emails are you sure of this? Text messages yes. But regardless you should be able to have all the services available to you while on a call. If not then like said there are some major issues that needs resolved.
    James
    12-23-2011 12:50 AM
  11. MrLorence's Avatar
    so then the real ?
    Is it an issue or not
    12-23-2011 01:14 AM
  12. yosteve's Avatar
    I'm listening to Internet radio and posting this in solid gray 4g anf gray 3g
    12-23-2011 01:20 AM
