Page 1 of 3 123 LastLast
Results 1 to 25 of 70
Like Tree8Likes
    Default My nexus is using INSANE amounts of data..
    I just got the nexus about 5 hours ago. In that time i used google music to stream 4 songs, and watched one 6 minute youtube video. So far the data usage is telling me that gmusic has used 220 mb of data, and the one video i watched used 40mb of data. I feel like there is something wrong here because I will easily be over 2gb by tomorrow at this rate. I used netflix/gmusic/youtube on my HTC incredible for hours a day before this and never went over my monthly 2gb. Is anyone else having this issue or is something wrong with my phone?
  2. #2
    Default Re: My nexus is using INSANE amounts of data..
    Quote Originally Posted by Whookam View Post
    Have you EVER had an LTE smartphone before?
    Verizon 4G LTE
    http://i.imgur.com/gXryt.png
    Premium1 likes this.
  3. #3
    Have you called Verizon to take advantage of their "Double Your Data for the same price?" Its a promotion so you might want jump on that very soon.
    Quote Originally Posted by milan03 View Post
    no the only other smartphone i've had was the htc incredible
  5. #5
    Default
    You used netflix, gmusic, YouTube hours per day without going over your 2gb?
    Pierce09 and VickMackey#AC like this.
    Quote Originally Posted by majiklantrn View Post
    No, i just heard about it now. I will be calling about that tomorrow
  7. #7
    Welcome to the LTE world my friend! All the rich media experience is going to be much easier to enjoy, in higher definition or bitrate. Very easy to run through your data cap in a few days.
    Verizon 4G LTE
  8. Thread Author  Thread Author    #8
    Quote Originally Posted by meth68 View Post
    Yeah, I used gmusic every day during my commute which was about an hour and a half total. And used netflix/youtube at night for atleast an hour. Some days I would use it even more. Each month my data usage was slightly under 2gbs
  9. #9
    DroidXcon's Avatar
    Posts
    Global Posts
    11,733 Global Posts
    ROM
    Stock for now
    download a data enabler toggle and disable mobile data when you are not using it.
    If i've made life easier buy me a Macchiato
  10. Thread Author  Thread Author    #10
    So basically you're saying that I can watch like 15 youtube videos and listen to a couple hours of gmusic per month before I'm paying per mb? LOL I kinda wish they wouldve told me that my data usage would increase by a factor of 50 before I got this phone. Looks like I'll be returning it... Even with 4gb I'd have to cut down my usage a completely ridiculous amount to stay under.
  11. #11
    DroidXcon's Avatar
    Posts
    Global Posts
    11,733 Global Posts
    ROM
    Stock for now
    thank goodness for grandfathered unlimited plan
    Thanked by:
    kath00
  12. #12
    japhule's Avatar
    Posts
    Global Posts
    330 Global Posts
    ROM
    Stock
    Did you have some music tagged for offline storage in google music? If you just got the phone, it may have pulled down your offline music to store on your phone.
  13. #13
    Nechasin's Avatar
    Posts
    ROM
    Something new!
    You also probably downloaded all your apps again.
  14. #14
    Darkblue31's Avatar
    Posts
    Global Posts
    198 Global Posts
    ROM
    stock
    I would suggest downloading all your apps, and pinning all your google music that you frequently listen to while on wifi, and then that should cut down on your use of mobile data. Along with doubling your data plan
    Its an Incredible feeling
  15. #15
    NotJustAPhone's Avatar
    Posts
    Global Posts
    10,442 Global Posts
    ROM
    GS3: CleanROM / N4: AOKP
    Some apps will also stream at a higher bitrate to give you better quality on an LTE connection. For example, Google Music will stream at higher quality on faster connections, which, of course, consumes more data.
  16. #16
    You can get “grandfathered unlimited data" still. Call verizon and ask to add the unlimited hotspot feature for $30 a month. Then call the next day and remove just the hotspot, and waaa laaa you have unlimited data for $30 a month
    ADD ME ON
  17. #17
    DroidXcon's Avatar
    Posts
    Global Posts
    11,733 Global Posts
    ROM
    Stock for now
    Default
    Netflix would kill me if I wasn't unlimited
    Thanked by:
    NoICon
  18. #18
    Quote Originally Posted by Holsum View Post
    It can't be that easy, can it?
  19. #19
    SuperChargedJ's Avatar
    Posts
    ROM
    Rascream + Trinity kernel
    Default
    Quote Originally Posted by DroidXcon View Post
    + 1
    Sent via Galaxy Nexus using Tapatalk
  20. #20
    Quote Originally Posted by SCampbell27 View Post
    Depends if Verizon has learned about this and/or you might need to call and hit up different reps until you get it.
  21. #21
    Ive never gone over 1gb. I simply just dont use that much data. Im on 3g, and verizon is saying ive used 1.5gb this month. It has slowed down though, but I think something was up for the first few days I had the phone.
  22. #22
    JoeNM84's Avatar
    Posts
    Global Posts
    205 Global Posts
    I used over half a GB in the first day of having the Nexus, but it was downloading apps and updates a lot for a good portion of the day. I do notice that Google Music uses a very large amount of data, I'm wondering if it has a bug in tracking the data used by it. I know that it starts caching the next song or 2 in your play list or whatever, but still seems high.
    edit: I'm 3G only.
  23. #23
    Channan's Avatar
    Keyboard Warrior
    Posts
    ROM
    Stock
    Why are you streaming your music if you only have 2GB? I don't listen to music a crazy amount of time and I've already used 4.15GB with Google Music since I got my phone last week.
  24. #24
    Dubbin1's Avatar
    Posts
    Global Posts
    428 Global Posts
    LOL I just checked my data usage for the first time. At the top of the list is Speed Test at 366mb. With my OG Droid I have never went over 250mb in a month. Thank God for unlimited data
  25. #25
    Channan's Avatar
    Keyboard Warrior
    Posts
    ROM
    Stock
    Quote Originally Posted by Dubbin1 View Post
    I take speed tests all the time. I've used 1.7GB in speed tests. :P
    Speed tests on 4G use 20MB though.
