Results 1 to 5 of 5
    Masheen's Avatar
    Android OG
    Posts
    Carrier
    Stock
    Exclamation Android Market Problem
    Android market v 3.4.4 keeps force closing whenever I open it or if it gets that far, try to download something. I did some research and others are experiencing the same problem. "Unfortunately, Market has stopped"
    [HL]GNEX Android Market -- Help please - Android Forums[/HL]
    I have tried wiping the app's data and cache through the application management menu. Neither seemed to work. The only fix that I've come across is the uninstall updates option in Settings/Applications. It then works for a brief period of time before automatically updating the market to 3.4.4 where it continues to force close.
    Is anybody here experiencing this issue?
  2. #2
    Default Re: Android Market Problem
    I am having exactly the same problem. Is there any solution?
  3. #3
    GNEX user here upgraded to IOs 4.0.2 and now i get that error all the time. Only temporay fix is yo clear market updates...and that only works one time
    How do I downgrade my OS back to 4.0.1???
  4. #4
    Poseign's Avatar
    Mobile Enthusiast
    Posts
    Global Posts
    1,105 Global Posts
    I dont understand... I thought everyone was already on 4.0.2?
    I heard that some CANADIAN GNex's were having issues after upgrading to 4.0.2.
  5. #5
    Quote Originally Posted by Poseign View Post
    Canadian GNEX user here the new market update has fixed the problem!
