DEAL OF THE DAY: Save 42% on the iBOLT Vehicle Charging Dock for Samsung Galaxy S3!
Results 1 to 12 of 12
    Default Light flow question
    after a lot of playing around in the complex menus I got Light flow to make the LED flash for different alerts when the phone is in sleep.
    I cannnot get it to flash at all to indicate "charging" battery run-down, or fully charged using the menu options. I thought maybe my battery power utlization app was conflicting and removed it, but can't get any alerts on power,. Has anyone set this up to work yet?? TX
  2. #2
    Default Re: Light flow question
    I only use it for the charge notification.
    Make sure you don't have the box checked to not show led when charging box under charge settings.
    Quote Originally Posted by pool_shark View Post
    I have screen one "Enable Light Flow and "Run in Foreground" checked
    Notification: Charging-
    Notification Type-- Not sure I understand "Prioriity Only vs "Cycle Very Slow", I;'ve tried both
    Then under "Notifications" I have "Charging Battery:"
    Enable Notification checkd
    Enable Light Checked
    A color selected...
    Do you know what I"m doing wrong??? Tx
    never mind!!! I think I got the priority thing right....I had checked Priority, and didnt see the sub menu where you set the priority...I had it very low. So I checked cycle on and off.... That might be an issue w/some of my other alerts.
    tx
  5. #5
    I am having an led flash every time the screen is off... any ideas????
  6. #6
    Default
    Does Light Flow need root for the galaxy nexus?
    OG Droid (The beginning of my smartphone obsession)
    Thunderbolt (The pitfall of early adoption)
    Galaxy Nexus (Toro-Cyanogenmod!)
    Galaxy S IV (Pre-ordered for Verizon)
    Quote Originally Posted by kesnik View Post
    No. I wouldnt know how to root and never used android before GNEX
    ... If you've used it before you should have no problem
    . I had trouble understanding all the options, also, how it wouldn't conflict w/settings I have on the phone.
    At one point I was getting double alerts for everything. A text would come in and I'd get two pings......It's a very powerful(no pun intended) app I think if you know how to use it. I pretty much disabled all the sound alerts in Light flo and just use it for the LED.
    I was getting absolutely no LED flashing before installing this app.
  8. #8
    Anyone know how to get it so the LED only comes on when fully charged, when having the Charged Battery notification on. Mine starts to flash at 90%
  9. #9
    Quote Originally Posted by hanano17 View Post
    It's in the charge settings. You can set it to show charging and charged. Turn it off for charging in notification settings.
  10. #10
    BSG75's Avatar
    Custom User Title
    Posts
    Global Posts
    1,055 Global Posts
    ROM
    Jelly Belly
    One thing I noticed with the charging indicator is that, for me, it doesn't work if you have the plug already in when you turn the phone on. Then it doesn't do the charging blink. It only blinks if you put the plug in after it's turned on.
    Also, as far the constant blinking, do you have it set to blink whenever there is a data signal? I think that is one of the options.
    Please use the Thanks button below and to the right.
  11. #11
    BSG75's Avatar
    Custom User Title
    Posts
    Global Posts
    1,055 Global Posts
    ROM
    Jelly Belly
    There is also a setting in the "Charged" notification area to control this called "Threshold." The default is 90%. You can also set it to 95%, 99% and 100%.
    Thanked by:
  12. #12
    Quote Originally Posted by BSG75 View Post
    Not sure how I missed that, thanks!
