I upgraded from the Thunderbolt and also recently installed a dual-band router with 2.4 ghz and 5 ghz. The Nexus picks up the 5ghz band, but my Thunderbolt wouldn't. The result is a much faster connection on the less crowded 5ghz band! Very nice!
Unfortunately, my wife's DINC can only connect to the 2.4 ghz band, which for some reason is a worse connection than the 2.4ghz on my old router. She has resorted to using 3G at home instead.
Now, I have to get an adapter to allow my Xbox to hook up to the 5ghz band and I will be set!
