Results 1 to 9 of 9
- 12-27-2011, 11:49 AM
Thread Author #1
Screen Brightness and Battery Life
I just turned off the auto brightness on my Nexus two days ago.
What I have found is that at least for me, the auto brightness just flat out stinks. It keeps the screen too dim in all lighting situations. I never saw how awesome our screens are until I set my own brightness (a couple of clicks below full).
I am not seeing any issues because of the pentile screen. This is a beautiful screen.
I have not seen any dramatic reduction in battery life. Like most every other 4G LTE smartphone I have owned, the battery life is poor. We keep trying to squeeze to out greater and greater power out of our devices on battery technology that is decades old.
Sent from my Galaxy Nexus using TapatalkSent from my Verizon Galaxy Note 2, Verizon Galaxy S3, or N7, or MacBook Air - 12-27-2011, 11:56 AM #2
Very true. I keep mine half way then crank to full when I want to show off some photos or video.
Thanked by: - 12-27-2011, 06:22 PM #3
- 08-28-2012, 11:12 PM #4
Re: Screen Brightness and Battery Life
i have my phone at the lowest setting for brightness....i raaarely make it bright (like the super mod said, only to show off pics/vids, and daaamn i forget how beautiful the screen looks) yet the battery settings shows the screen hogging up around 50% usually.....why??
i dont use the phone that much throughout the day so im confused to why it drains so quick. - 08-29-2012, 05:15 AM #5
I prefer brightness set at the lowest setting with the bar all the way under the check box. Any brighter hurts my eyes - especially at night. This really helps battery life too.
- 08-29-2012, 05:17 AM #6
50% just means that 50% of battery usage was display. This does not mean display drained 50% of your battery. It means you didn't do much with the phone other than turn the display on.
For example maybe you discharged only 10% of the battery but 50% of that 10% was display which would be 5%. - 08-30-2012, 01:17 AM #7
I think the auto-brightness setting is usually too high.. In a dark room, I can have it on 1% and it is more than bright enough still..
Only time I may have a hard time is if I am looking at it in direct sunlight. - 09-02-2012, 12:12 AM #8
- 09-02-2012, 03:57 PM #9
Reply
