1. trunks527's Avatar
    Had the phone since launch, just noticed the charging symbol on the battery isn't going away. Happening to anyone else? Fixes? Thanks.
    12-28-2011 01:11 AM
  2. DaPoets's Avatar
    could easily be a software issue but have you done the simple thing like take the battery out?
    12-28-2011 01:27 AM
  3. trunks527's Avatar
    Yes sir as well as a sim card pull and factory reset. Just started happening today.
    12-28-2011 01:29 AM
  4. DaPoets's Avatar
    Exchange it... too new to have issues like that if you have done the reset, bat pull, and sim...
    12-28-2011 01:53 AM
  5. dmmarck's Avatar
    You mean when the phone is on, on the blue? I have yet to have it go away, even at full. I called VZW; it didn't go away on their model there nor a nearby RAZR.
    It does go away when the phone is off, revealing an all white battery.
    01-01-2012 01:35 PM
  6. trunks527's Avatar
    The lightning bolt on the battery. It kept causing my phone to turn the screen on as well. Just exchanged my phone
    01-01-2012 02:02 PM
  7. dmmarck's Avatar
    Oh yeah mean when the phone is powered off but is charging, correct? Yeah mine doesn't do that lol
    01-01-2012 02:03 PM
  8. trunks527's Avatar
    When the phone is powered on I mean. The blue battery has the lightning bolt and was causing huge battery drain.
    01-01-2012 02:06 PM
  9. dmmarck's Avatar
    Oh weird. Even when you unplug? Yeah that's probably a problem lol. Did they give you grief on the exchange?
    01-01-2012 02:09 PM
  10. trunks527's Avatar
    Yes sir. Called tech support and they made a notation on the account. No hassle easy exchange.
    01-01-2012 02:11 PM
  11. dmmarck's Avatar
    Ok good to hear. At first I was worried that the icon staying on past full charge was destroying your battery. I sorta sharted a bit with that presumption lol
    01-01-2012 02:13 PM
