Results 1 to 11 of 11
    Default Battery charging icon won't go away?
    Had the phone since launch, just noticed the charging symbol on the battery isn't going away. Happening to anyone else? Fixes? Thanks.
  2. #2
    DaPoets's Avatar
    Posts
    ROM
    4.0.3 Codename 1.5.0
    Default Re: Battery charging icon won't go away?
    could easily be a software issue but have you done the simple thing like take the battery out?
    DaPoets
    ~ Galaxy Nexus LTE Codename Android ROM 1.6 (ICS 4.0.3)
    ~ Motorola Xoom LTE Codename Android ROM 1.5.5 (ICS 4.0.3)
    ~ Droid Charge as 24/7 4G Unlimited Tether Bot on Stock
    G1000 -> PPC6600 -> PPC6700 -> OG Droid -> Galaxy S Fascinate -> Pure Bliss
    Default
    Yes sir as well as a sim card pull and factory reset. Just started happening today.
  4. #4
    DaPoets's Avatar
    Posts
    ROM
    Exchange it... too new to have issues like that if you have done the reset, bat pull, and sim...
    DaPoets
  5. #5
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    What do you think?
    You mean when the phone is on, on the blue? I have yet to have it go away, even at full. I called VZW; it didn't go away on their model there nor a nearby RAZR.
    It does go away when the phone is off, revealing an all white battery.
    Default
    The lightning bolt on the battery. It kept causing my phone to turn the screen on as well. Just exchanged my phone
  7. #7
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    What do you think?
    Quote Originally Posted by trunks527 View Post
    Oh yeah mean when the phone is powered off but is charging, correct? Yeah mine doesn't do that lol
  8. Thread Author  Thread Author    #8
    Default
    When the phone is powered on I mean. The blue battery has the lightning bolt and was causing huge battery drain.
  9. #9
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    What do you think?
    Oh weird. Even when you unplug? Yeah that's probably a problem lol. Did they give you grief on the exchange?
  10. Thread Author  Thread Author    #10
    Default
    Quote Originally Posted by dmmarck View Post
    Yes sir. Called tech support and they made a notation on the account. No hassle easy exchange.
  11. #11
    dmmarck's Avatar
    Retired Moderator
    Posts
    ROM
    What do you think?
    Ok good to hear. At first I was worried that the icon staying on past full charge was destroying your battery. I sorta sharted a bit with that presumption lol
B
