Results 1 to 5 of 5
    WhenForever's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Charging issue
    I've only had the gnex for a few days but i've noticed an issue with the charging and i'm not sure if its a defect with mine or a common problem. I charged it overnight, when I woke I checked my phone and the lock screen said charged on it but I noticed the battery icon still had the lightning bolt in it indicating it was still charging. I looked at battery info in settings and it said 99% - full. I unplugged it and plugged it back in and it went to 100% - full in just a few minutes but the battery icon was still saying it was charging. I unplugged it and went about my day. Last night I plugged it back in and this morning I woke up to it saying it was charged but it was 98% - Full. Anyone else seen this or have this happen? Wondering if I should take it back and have it swapped out for a new one or if there is a fix
  2. #2
    lousvette's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Charging issue
    It's normal. Does the same thing to me. Only time I see 100% is if I disconnect it as soon as its finished charging.
  3. #3
    p08757's Avatar
    ** Superhero **
    Posts
    Global Posts
    2,067 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Most of the time I only see 99%. As long as you are getting "normal" battery life I would not worry about it.
  4. #4
    chevyguy8893's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    DarkAOSP v3.0.0
    As stated above, it's normal. The phone stops charging when it reaches 100% to prevent overcharging the battery, and then charges again at 95% I believe to top it off if it is still plugged in.
  5. #5
    dmmarck's Avatar
    Retired Moderator
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    What do you think?
    Absolutely normal. As I stated in another thread, the white lightning over the blue icon on the top right occurs normally. I even called VZW; it happened on their test unit AND a RAZR. I'd appreciate the white lightning going away, but perhaps it just indicates it's plugged in? Or maybe, b/c the GNexus eats so much powah, it is just always charging? lol.
    Sometimes it'll get to 100% - Full, but usually 100% - Charging.
