- 12-28-2011, 07:15 PM
Thread Author #1
- 12-28-2011, 08:07 PM #2
- 12-28-2011, 08:12 PM
Thread Author #3
- 12-28-2011, 08:19 PM #4
Yeah, ICS does not natively support .wma files. Sorry man.
*customized tapatalk signature* - 12-28-2011, 09:13 PM #5
Re: Help. Why is my gnexus not recognizing. wma files
Gee... I wonder why ANDROID doesn't support WINDOWS Media files?
- 12-28-2011, 09:26 PM #6
- 12-29-2011, 07:37 PM #7
- 12-29-2011, 08:05 PM #8
Agree, D load one of the several apps for that....presto.
- 01-01-2012, 03:35 PM #9
- 01-01-2012, 05:07 PM #10
- 01-03-2012, 04:51 PM #11
- 01-03-2012, 05:30 PM #12
The fact that wma isn't supported tells you something about that particular format IMO. It's on its way out. iTunes will convert your wma files to acc if you try and add them I think (at least it used to). I used Windows machines for 15 years and WMP was like the worst piece of software ever.
- 01-04-2012, 02:32 PM #13
I want to amend my earlier comment. I converted all of my music to mp3 files, and I'm having the exact same problem. About half my collection won't sync to the GNex. So it doesn't matter which format the files are in. If I try to specifically sync one of the Albums that didn't sync, WMP says that the files are already on the device. They're not. Confirmed with file manager. I'm confinced that GMusic does something to spoof the operating system into thinking that music uploaded to GMusic is already on the device, so that it shouldn't be copied. I've tried WMP, Winamp and DoubleTwist. They do the same thing. If I manually copy the files to the GNex, they don't show up in GMusic. If I make online music available, and check the option to make such an album available offline, it downloads the music, but then doesn't show up as soon as I tell the device to only show local music. This is driving me off the edge!
- 01-04-2012, 03:15 PM #14
Really wish I could help you here. I just play my music OTA from google music. After the first time playing the song it will be cached on your device so it doesn't have to download it again, at least until you clear the cache.
Only thing i could think of: Do you use iTunes on your home PC? Google music has that option to sync music from iTunes if iTunes is installed. I do all of my syncing that way and havent had any problems with WMA playback, probably because iTunes converts the WMA files after you add them. - 01-04-2012, 03:18 PM #15
- 01-04-2012, 03:37 PM #16
Question: Can you just drag/drop the music files straight to the phone's memory and have it end up in music app like I can do with my Dinc now (I can put it on the SC card or the internal phone's memory)?
I have no desire to synch or cloud or stream anything. - 05-03-2012, 10:20 AM #17
Reply
