1. sc0rpion's Avatar
    How in the world can I select a custom ring tone on ICS? I have the MP3 on my phone..I can play it in music player, but I can find a spot to set it as my ring tone..can someone help?
    01-01-2012 02:29 PM
  2. jpbass7's Avatar
    User ringtones go in /sdcard/Ringtones, notifications go in /sdcard/Notifications.
    Wolfroid likes this.
    01-01-2012 02:33 PM
  3. sc0rpion's Avatar
    Cool...thanks. Works
    01-01-2012 02:35 PM
  4. pool_shark's Avatar
    Actually the can go anywhere, you just have to choose music instead of system.
    I have a few songs I use as ringtones that are in /my music/artist name.
    01-01-2012 02:48 PM
  5. jpbass7's Avatar
    Yep. This, too. I usually make my own ringtones (not full tracks), so I just store them in the system locations and keep them out of my music folders.
    01-01-2012 03:00 PM
  6. daihard2008's Avatar
    Found this thread while googling for some info. Is it possible to set a ringtone per contact without using apps like WhoIsIt? I'd think a feature like that should be built into an OS by now.
    Thanks!
    03-31-2012 12:40 PM
  7. ShinyTop's Avatar
    In People you can choose a contact, hit menu button, then set ringtone.
    03-31-2012 12:48 PM
  8. daihard2008's Avatar
    Thank you! I was hoping that I was missing something. I sure did!
    03-31-2012 01:15 PM
  9. Wolfroid's Avatar
    Thanks for the answer, but I haven`t had any File app on ma` Nexus preinstalled.
    Now, when I downloaded the Astro File Manager / Browser from Google Play everything is much easier.
    07-15-2012 06:31 AM
