Results 1 to 25 of 36
- 01-01-2012, 03:04 PM
Thread Author #1
-75dBm a generic signal level?
So I've been testing LTE here in NYC pretty much since the Thunderbolt's launch day, done my fair share of "node hunting", and I've found a dozen of perfect locations where I'm literarily a few feet away from DAS or the actual eNodeB.
In those situations, I would normally get signal level as low as -25dBm and certainly lower than -51dBm on my ThunderBolt, Rezound, or UML290 AirCard.
Visiting those same locations with my Galaxy Nexus I seem to be hitting the threshold of -75dBm for any signal that's the same or better. I've been testing within LTE environment so I can't speak of 1x or EvDO, but this is rather strange. Simple SIM card swap from GN to my other devices show signal in the -30dBm range.
I'm curious to hear your experiences in the similar environment.
P.S. the data performance is pristine so this thread is simply about signal reading under the optimal conditions.Verizon 4G LTE
- 01-01-2012, 03:15 PM #2
- 01-01-2012, 03:18 PM
Thread Author #3
- 01-01-2012, 03:34 PM #4
Re: -75dBm a generic signal level?
i am positive i was on 4g in Harrisburg.......i know because i was in the passenger seat of my brothers car specifically staring at my phone like an ***** looking at signal strengths and then running speed tests.....i was surprised to see it read lower than -75dbm because that had been the first time i ever saw a reading below it.
- 01-01-2012, 03:42 PM
Thread Author #5
- 01-01-2012, 03:53 PM #6
I got a -73 one time but that was the lowest I got.
- 01-01-2012, 03:53 PM #7
Even comparing 3g signal on nexus and droid razr, i get around -78dbm on razr at my house and on galaxy nexus I never get any better than -93dbm, however it is pretty consistant at that and I doesn't get any worse and with the razr it was -80dbm at my house consistant.
That was 3g to 3g signal comparison as razr always displays the 3g signal in signal info menu, from what the reports are saying. But with razr I never had random dropouts in data, with nexus sometime it would go from 2 bars to no bars and no data and reconnect and would do it every few hours or so.
That usually happens on 4g, 3g signal never has issues. If the data dropouts were every 4 mins I would be done with this phone. My replacement from amazon gets here on tuesday and I will see if it is my phone or not.
The best i have gotten is -75 like others have said, that was in the middle of the town. - 01-01-2012, 04:05 PM #8
- 01-01-2012, 04:22 PM
Thread Author #9
- 01-01-2012, 05:10 PM #10
- 01-01-2012, 05:39 PM #11
I am in NYC and have -77dbm at the moment
- 01-01-2012, 05:43 PM #12
- 01-01-2012, 06:30 PM
Thread Author #13
Verizon 4G LTE
- 01-01-2012, 09:11 PM #14
- 01-01-2012, 09:58 PM #15
EVDO 3G at my home hovers at -93 dBm on my GNex, while another phone I have gets -87 at the same exact location.
I think the radio in the GNex just plain old sucks.
Thankfully, with VZW, all you need is the minimalist signal to make a call.
Verizon Galaxy S3 LTE - CyanogenMod 10
- 01-01-2012, 11:02 PM #16
- 01-02-2012, 09:48 AM #17
- 01-02-2012, 11:43 AM #18
- 01-02-2012, 11:50 AM #19
- 01-02-2012, 07:33 PM
Thread Author #20
Since most (all) of us are seeing the same exact values, it leads me to believe that they're representing the actual bars... I've never seen a value other than these 6 generically quantized:
-120 (0 bars), -113 (1 bar), -100 (2 bars), -93 (3 bars), -83 (4 bars), -75 (5 bars or better).
If anyone has more insight on this, please chime in. All I know, I can't wait to get the next OTA, which I'm hoping will offer standard dBm values.Last edited by milan03; 01-02-2012 at 07:45 PM.
Verizon 4G LTE
- 01-02-2012, 08:15 PM #21
- 01-02-2012, 08:44 PM #22
- 01-02-2012, 08:45 PM
Thread Author #23
Verizon 4G LTE
- 01-02-2012, 08:50 PM #24
I always get 2 bars at -93dbm, I only get that strength at 3g signal. 4G is usually around -93dbm to -120dbm.
It is really outrageous that the phone is so unstable on 4g. 3g signal never fluctuates for me.
4g signal goes from -93 to -110dbm sitting in the same location and sometimes totally drops it(happens like a once an hour). I have 4g most of the time at home, but I don't see a reason for a phone to be jumping around that much. LTE signal is suppose to better at penetrating buildings but it very unstable on this phone specially in a residential area round the edges of the city.
I had the razr and the 4g signal was so much more stable on that phone. It just seems like this phone is jumping around to different towers all the time and not picking up the best signal. If I get -93dbm for a few minutes and than -104dmb for the next 20 mins, I don't understand why it would jump to -120dbm and totally drop signal the next min. - 01-02-2012, 09:45 PM #25
Reply
