1. BringMeBack9801's Avatar
    I was wondering if it's possible to adjust the touch sensitivity because I've noticed that, on the home screen for instance, if you swipe to a different screen, don't touch the display for about 3-4 seconds, then resume trying to swipe, there is a slight delay of about a second. It is almost as if the display shuts off touch response temporarily. Anyone else notice this and is there any way to fix it?
    01-02-2012 10:10 PM
  2. iBowToAndroid's Avatar
    No way to calibrate/adjust sensitivity that I've seen, sorry
    01-05-2012 12:52 AM
