Stock calendar. All looks good when I look at the calendar on google/computer.
Phone set to sync with my google calendar and add on calendars.
I have repeating events, add on calendars for sports, holidays, phases of the moon and regular calendar entries.
Set on my phone to sync all of these.
When I open the calendar on the phone it does not show the sports. There are solid colored lines across the top of the calendar with no printing visible. When I click on one it brings up the edit screen for that entry.(the repeating events)
Are all these issues due to a buggy app? Hope to fix in an update? Or do I need to change something on the phone?
Thank you.
Thank you.
