Results 1 to 8 of 8
- 01-08-2012, 06:16 AM
Thread Author #1
Auto power-on after charging "drained" phone
Hi all,
New android user here with the Gnex...
Today my phone went dead due to out of battery (not surprising
)...when I plugged it in, the big white battery icon shows up indicating it is re-charging. However it appears the phone never turns back on even after it is done charging.
When I had my iphone, and I charge it after it has been completely drained, the phone will turn itself back on after it got 10 or 15% charge back. Is there a way to make the Gnex do something similar?
Thanks in advance! - 01-08-2012, 12:05 PM #2
Re: Auto power-on after charging "drained" phone
Most phones don't do that. My Palm Pre phones did that and I hated it. Sometimes I prefer to keep my phone off for a while to charge it quicker. If not, I can turn it on myself.
- 01-08-2012, 12:42 PM #3
I've never had a phone that does that. I think that the iphone for whatever reason seems to need to be powered up in order for the battery charge. I know that the ipod will do the same thing. But, if I physically turn the device off, and then plug it in, it will not charge. So, I think when the battery is at a certain level, it needs to be powered up in order for it to be charged fully. I personally do not like that.
- 01-08-2012, 01:01 PM #4
Yea, my iPad does this. Sometimes I like it, sometimes I don't. But to answer your question, the Galaxy Nexus doesn't do that. You're going to have to manually turn the phone back on. I would like it to turn on after being fully charged, but that seems unlikely to happen.
So many phones, so little time. - 01-08-2012, 02:18 PM #5
- 01-08-2012, 03:05 PM #6
I'm glad my phone doesn't turn itself back on automatically. If I turn it off to charge I want it to stay off
Sent from my Galaxy NexusSGSIII : White 32 gb model with 32 gb sdcard
RoM : CleanRom 5.5.1_ jb
Kernel : n/a - 01-09-2012, 02:00 AM
Thread Author #7
Thanks everyone for the feedback. If I can just turn it on shortly after I plug it in, that would work for me. I just don't want to have to wait until the phone is charged before I can turn it on, as I may be missing important phone calls.
- 04-26-2012, 10:08 PM #8
if you leave it off the whole time is there a way to tell when its done charging?
edit: figured it out, tap the power buttonLast edited by sddfdds; 04-26-2012 at 10:22 PM. Reason: figured it out
Reply
