Results 1 to 6 of 6
    Default Keyboard Issue on Nexus
    Hi, all, first time poster on here.
    I've been having a problem with my keyboard and wondering if anyone has run into something similar or if anyone thinks this is a hardware problem. Every now and then when I try to use the keyboard, it won't respond - the keyboard vibrates upon touch and I can see the autocorrect changing but no text appears. Then it's fine after a reboot.
    I was running Revolution and tried a different ROM (AOKP) and still got the same problem. I was using stock keyboard the whole time so went to Swiftkey and still getting the same issue.
    Should I return the phone for another one? Still within January 15 for a few more days...
    Thanks in advance!
  2. #2
    albokay's Avatar
    Posts
    Global Posts
    536 Global Posts
    Carrier
    STOCK
    Default Re: Keyboard Issue on Nexus
    Im also having the same problem. When it happens the clock in the notification bar freezes as well.Widgets show the correct time though
  3. #3
    Poseign's Avatar
    Mobile Enthusiast
    Posts
    Global Posts
    1,105 Global Posts
    Either of you using a task killer? I dont believe I've ever had this problem.
  4. #4
    daso's Avatar
    Posts
    Global Posts
    224 Global Posts
    I had this problem for a day and it didn't happen again after a reboot.
  5. #5
    albokay's Avatar
    Posts
    Global Posts
    536 Global Posts
    Carrier
    STOCK
    Nope. Never had a task killer installed.
  6. #6
    all swipe key boards not working on my Verizon galaxy nexus ?
