Results 1 to 9 of 9
    SSHGuru's Avatar
    Banned
    Posts
    Global Posts
    662 Global Posts
    ROM
    Lithium
    Default Very strange and upsetting battery issue...
    Or Nexus issue...
    As I do every night I plugged in the Nexus next to my bed (it was at about 35%) and went to sleep.
    As I do every morning I picked it up and hit the power butting to see what was going on.
    Today however when I hit the power button - nothing - nada. I tried holding it down - nothing. Dead.
    Keep in mind this is the extended battery and yes the charger was working and plugged in. I unplugged it and tried it - nothing. I removed the battery and put it back in - nothing.
    So I went to the other room, grabbed my original battery and put it in. It instantly booted up no problem at 95%.
    I decided to try to extended again. I took out the original and put in the extended and it came right up.
    Keep in mind I didn't say "booted up", literally it just worked as if I had not swapped batteries. I pulled it and put it back in again and still it didn't boot up it just came on. (like a hot swap)
    The one wildcard here is that I kept the phone plugged in the entire time except when trying to get the extended working after a pull.
    Now I have the extended in and it's working fine. And when I did finally get the extended to boot the battery symbol came up first as empty and then a second later as full.
    Defective Nexus, Battery, or just bug?
  2. #2
    dhawk1202's Avatar
    Posts
    ROM
    AOKP/ Franco Kernal
    Default Re: Very strange and upsetting battery issue...
    I've only had my extended battery for 1 night so far, but I have noticed a couple times while using Solo Battery Widget it will show the wrong % for about 5 seconds then show the correct %. This did not do this yesterday with my standard battery. Hopefully your issue is a fluke.
    SSHGuru's Avatar
    Banned
    Posts
    Global Posts
    662 Global Posts
    ROM
    Lithium
    My issue is that if I didn't have the standard around it would have never turned on....
  4. #4
    Default
    I can't say anything about the battery issue because I don't have an extended one. If I read the rest correctly though, I can say that your phone didn't reboot when you swapped batteries because your phone was still powered by the AC charger.
  5. #5
    dhawk1202's Avatar
    Posts
    ROM
    AOKP/ Franco Kernal
    Quote Originally Posted by svenEDGE View Post
    Agreed.
    SSHGuru's Avatar
    Banned
    Posts
    Global Posts
    662 Global Posts
    ROM
    Lithium
    That's interesting - I didn't know you could hot swap batteries as long as you were plugged in.
    However I still have the issue of why the Extended failed to wake up and why it took the standard to get everything working...
  7. #7
    I can only say that I have had the extended battery from day one...never put the original battery in the phone.....and I havent had any issue with it. From my personal experience I would say its just your battery. But your right.....that is a strange and upsetting battery issue.
  8. Thread Author  Thread Author    #8
    SSHGuru's Avatar
    Banned
    Posts
    Global Posts
    662 Global Posts
    ROM
    Lithium
    If it happens again I'll exchange the battery.
    SSHGuru's Avatar
    Banned
    Posts
    Global Posts
    662 Global Posts
    ROM
    Lithium
    Well today in the middle of a call the phone re-booted. First time ever. So I called tech support and they said I had a bad extended battery but they were OUT (again).
    They called my local store and told me I could go there and exchange it. I went there and at first they thought they were out and found ONE. They swapped it out and I'm using it now.
    I also bought the Verizon Silicon Black Cover - it fits the extended even better than the standard IMHO and looks nice.
