- 01-18-2012, 11:10 AM
Thread Author #1
Bluetooth Not Connecting Automatically
I searched the Galaxy Nexus forums, but did not see anything pertaining this topic.
I am having a problem with my Galaxy Nexus automatically connecting to my car's bluetooth when I turn on the car.
Bluetooth is enabled on the Nexus, and the car and phone are paired, and work fine sometimes. This morning I started the car and watched as the phone did not connect, so I shut the car off, shut the phone off and did a battery pull to restart the phone. When it restarted I started the car and the phone and car connected automatically as it should.
I AM using "AutomateIt" to automatically perform certain tasks that have to do with Bluetooth. I disabled it to see if it was causing a problem, but after the battery pull, it is connecting reliably whether AutomateIt is enabled or not. If the problem resurfaces, should I uninstall it to see if the problem disappears? I have it set up and it works reasonably well, so I hate to delete all of those settings and start over if that's not what's causing the problem.
Thanks
TONY
- 01-18-2012, 02:20 PM #2
Re: Bluetooth Not Connecting Automatically
i have the same problem....90% of the time the phone connects automatically with the car sometimes not...its usually when i jump in the car, start it, then i will text or something like that the phone will.not connect...i just power off powee on and it works fine
- 01-18-2012, 03:11 PM #3
It could be an installed app interfering. Or it could be the car's bluetooth. What is it connecting to?
I have no problem connecting automatically with Microsoft Sync on my Ford Edge so it does work the way it's supposed to in the right circumstances.
If I could only figure out how to make it stop playing Google Music when it connects I'd be a happy camper. - 01-18-2012, 03:17 PM
Thread Author #4
- 01-18-2012, 04:46 PM #5
- 01-18-2012, 05:08 PM #6
I experience that with my bluetooth periodically too. It happens on the bionic as well. I will usually turn off the bluetooth on the phone and then back on.
Sent from one of the following: Nexus, Bionic, or Xoom using TapatalkSent from my Verizon Galaxy Note 2, Verizon Galaxy S3, or N7, or MacBook Air - 01-18-2012, 05:17 PM #7
I experience the same thing. I had to do a battery pull, next time I will try the airplane mode switch.
- 01-18-2012, 05:19 PM #8
This just started in the last two days for me. I use the T505 and the S9 HD from Motorola. The phone acts like it lost the "pairing" but on the T505 it won't play music or calls and when I turn off Bluetooth I hear "connection dropped". Battery pull seems to work but I will try airplane mode next.
Sent from my Galaxy Nexus using Tapatalk - 03-28-2012, 07:46 AM #9
Sorry for what may be a dumb question. I have my Nexus paired with my Altima, but it does not connect automatically. I have to actually turn it on when I get in the car and off when I get out to conserve battery. I've missed a few calls as I forget to turn it on sometimes in the car and forget about hearing it ring in my pocket. I've tried to go into Bluetooth settings and can't figure it out. Any help? Thanks!
- 03-28-2012, 09:29 AM #10
In my experience with the gnex Bluetooth, I have found that it will only automatically pair to the last device it was connected to. It becomes a bit frustrating if you use two bt devices, because you have to set them in pairing mode sometimes.
- 03-28-2012, 12:41 PM #11
- 03-29-2012, 08:45 AM #12
- 03-29-2012, 02:52 PM #13
With this phone i haven't experienced any difficulties getting it to connect. I have two devices paired with it. My Motorola Oasis and a CB radio that has Bluetooth in my truck.
Sent from my Verizon Galaxy Note 2, Verizon Galaxy S3, or N7, or MacBook Air - 03-30-2012, 07:47 AM #14
Same with my T505. I bought another after giving my old on to my wife. Everything seemed to work better. Then I left it pair with my wife's iPhone, and now it's lost it's mind.
What seems to work best for pairing, for me, is to drive a few houses away before powering the T505 and make sure the wifi is shut off. Pair will work most of the time.
After upgraded to the 4.0.4 radio, the wifi doesn't seem to matter as much, but I now do it out of habit.
Reply
