1. mscalero's Avatar
    Hello,
    I have been having an issue with my Galaxy Nexus. Sometimes, at random, when I get an incoming call and answer it, the call volume for the speaker will be pushed up to maximum volume.
    I tend to set the volume of the speaker to have 1/2, but sometimes it just sets itself to the max and I do not know why. I don't really use the speaker phone either, so it's not the speakerphone setting.
    Any advice?
    Mike
    01-31-2012 08:50 AM
  2. mscalero's Avatar
    Anyone have any suggestions here?
    02-14-2012 02:29 PM
  3. Jasper's Avatar
    Yes, do you listen to pandora? Watch movies? Play games? If you do and u turn your volume up.... thats why ur speaker volume is up.
    02-14-2012 02:55 PM
  4. mscalero's Avatar
    Hello,
    I do, but aren't Media volume and In-Call volume separate? Even so, when i answer a call it is as the MAX volume, I never set my media volume that high.
    M
    02-14-2012 03:00 PM
  5. Jasper's Avatar
    Your correct, i just played with it. Speakerphone and regular speaker are not affected by media volume controls. They do use the same volume control, speakerphone volume affects regular ear speaker volume. Not sure why its defaulting to max though.
    02-14-2012 03:14 PM
  6. zen0s's Avatar
    Did you ever get to find out what was causing this issue? I don't have nexus but I have same problem with galaxy note 2. In-call volume goes up to max randomly... And I can't seem to find any answers for this issue.
    12-03-2012 04:59 PM
