1. fire125k's Avatar
    why can I get data when I'm.on a call. My thunderbolt did it when I was 4g or 3g. Now the sec I get a call I lose data..... It really sucks if using the GPS and I get a call.
    02-01-2012 10:54 AM
  2. lakaw's Avatar
    The Thunderbolt as well as the Rezound are SVDO capable. GN is not.
    02-01-2012 11:17 AM
  3. sisblub's Avatar
    I don't know what SVDO means but I thought you couldn't get data and voice using 3g because they use the same radio. You should be able to get both voice and data if you're on 4g though.
    02-01-2012 03:32 PM
