Results 1 to 15 of 15
    Mooondog's Avatar
    Posts
    Global Posts
    68 Global Posts
    Default Voicemail issue.....very strange
    I can't access my voicemail account from the GN. I can from a land line. They've opened up a trouble ticket. Sounds like it's a device issue. How is that possible? I calls the voicmail line. My connection is good. The signal tones seem loud and clear.
    bizarre....
    Any thoughts on what it may be?
    edit: to be clear...when I put in my password, it says the password isn't correct.
  2. #2
    9KRacing's Avatar
    Posts
    Global Posts
    324 Global Posts
    ROM
    Gummy Nex
    Default Re: Voicemail issue.....very strange
    You must be one of the 3 people not using Google Voice. :P
    Mooondog's Avatar
    Posts
    Global Posts
    68 Global Posts
    Quote Originally Posted by 9KRacing View Post
    ha ha..nice... Well, it wasn't working on my work voicemail either. It's funny, the pre-programmed passwords I input on the contact would work. But if I manually enter passwords it wouldn't.
  4. #4
    It is very true. I cannot use the Visual VM program either. None of the VM's show up, and when I call in through the phone, no dice.
    I guess I'll tunr my Gvoice back on then.. Kind of sucks though.
  5. #5
    Default
    Quote Originally Posted by Mooondog View Post
    bizarre....
    All three may work:
    Don't use speaker phone.
    Program your password automatically into dialing your voicemail.
    Switch to long tones in your phone settings.
    Mooondog's Avatar
    Posts
    Global Posts
    68 Global Posts
    Quote Originally Posted by yosteve View Post
    All three may work:
    Didn't work either on or off speakerphone.
    Yes...I should program my password
    already switched to long tones
    Anyway, havn't gotten a call back from VZW but now all of the sudden it is working again. Go figure.
  7. #7
    I use Google Voice, but for the first message I ever received (even though I had Google Voice voicemail set up), a normal voicemail notification showed up in my notification bar. And now it won't go away!
    My Verizon voicemail inbox is empty.
    Please help.
  8. #8
    merloquin's Avatar
    Posts
    Global Posts
    11 Global Posts
    ROM
    Stock
    bizarre....
    Asked and answered:
    does your *86 for voicemail work?
  9. #9
    Default
    does that mean you didn't try it as a possible fix?
  10. Thread Author  Thread Author    #10
    Mooondog's Avatar
    Posts
    Global Posts
    68 Global Posts
    it started working again and haven't programmed it yet. I will right now though. thanks
  11. Thread Author  Thread Author    #11
    Mooondog's Avatar
    Posts
    Global Posts
    68 Global Posts
    So VZW just followed up on the trouble ticket. Said that Samsung is aware of this issue with the GN and working on a fix. Said people have been successful by turning the volume down on the phone before keying in tones. Gonna issue an OTA at some point. Glad to know it wasn't me going crazy.
  12. #12
    Cigar-Junkie's Avatar
    Posts
    Global Posts
    523 Global Posts
    ROM
    Stock
    Default
    Did you try a battery pull?
  13. Thread Author  Thread Author    #13
    Mooondog's Avatar
    Posts
    Global Posts
    68 Global Posts
    Quote Originally Posted by Cigar_Junkie View Post
    Yes....when I first had the issue, pulled the battery, sim, and restarted. Didn't fix it.
  14. Thread Author  Thread Author    #14
    Mooondog's Avatar
    Posts
    Global Posts
    68 Global Posts
    So I called voicemail. Keyed in my password and it again said "you have entered the wrong password" or whatever... I immediately lowered the volume from high to low (which is what VZW recommended) and then it worked. This was on the same call.
    So yeah....there is definitely some type of bug.
  15. #15
    Nirvana328's Avatar
    Posts
    Global Posts
    91 Global Posts
    ROM
    stock
    Quote Originally Posted by airasiv View Post
    Please help.
    This worked on my GSM Galaxy Nexus, maybe it will work on the Verizon version:
    Go to:
    SETTINGS > APPS > ALL > PHONE > CLEAR DATA
    If you don't see an app called PHONE, try looking for one called VOICEMAIL and clear data there.
    edit
    so apparently what I wrote above is really only a temporary fix until the app reloads its data and again shows the never ending indicator.
    What I ended up doing randomly was just calling my carrier for tech support and they were able to send a reset signal to clear out my voicemail indicator. So essentially the tech support just cleared out the system's voice mail indicator and that fixed the problem. I personally use Google Voice for voicemails so I can't say if this will reset your voicemails, but from my experience I didn't have to reprogram my voicemail service or settings (for the carrier). But I would double check with the tech support just in case. Cheers!
