Results 1 to 4 of 4
    dubge's Avatar
    Posts
    Global Posts
    1,384 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Always changing
    Default battery charging questions
    So when charging the lock screen gives you the % and when it is charged it says charged, but if you go into the phone while still plugged in the battery icon in the top right corner still has the lightning bolt like it is still charging, also if you go into the battery stats while plugged in it says 100% charging.
    Question is will these ever say charged or not show the lightning bolt when plugged in?
  2. #2
    recumbentbob's Avatar
    Posts
    Global Posts
    64 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: battery charging questions
    Quote Originally Posted by dubge View Post
    When plugged in the lightening bolt is always there.
  3. #3
    davidnc's Avatar
    Posts
    Global Posts
    8,984 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    Also when mine is totally charged it shows charged
  4. #4
    yosteve's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    I use battery indicator to show my battery as a percentage but it displays it on the left.
