1. CFD323's Avatar
    When I am connected to wifi, it disconnects when the phone sits idle for a while. It does it at home as well as work (wireless-G at home, N at work...different setups on routers at both places...)
    Does anyone know why this happens, and how to fix it? IT"S PISSING ME OFF!!!
    02-02-2012 11:17 AM
  2. recumbentbob's Avatar
    Mine doesn't do that.
    Maybe it's an app messing with you?????
    02-02-2012 11:30 AM
  3. CFD323's Avatar
    Yeah it's been doing it for a while and I'd hate to have to delete all 75+ apps and reinstall them back 1 at a time to see if that's the problem, and then which app is causing it. But i might have to....
    02-02-2012 01:09 PM
  4. svenEDGE's Avatar
    I don't know if you are rooted or not but there is an app called SwitchMe that you could try. It let's you have multiple users on one phone. You could create a profile and use it to test your phone without a certain app without actually having to uninstall them all.
    02-02-2012 01:20 PM
  5. Danv1369's Avatar
    Does it disconnect after the screen turns off?
    Check this setting and turn wifi to keep wifi on
    Settings>Wifi>menu(3 dots)>Advanced>Keep Wifi on during sleep to Always
    02-02-2012 03:24 PM
  6. CFD323's Avatar
    Yeah that's set right...still does it...
    02-02-2012 07:42 PM
  7. CFD323's Avatar
    Not rooted....
    will have to look into that app, but I've got so many apps it could take forever to try them one at a time...
    02-02-2012 07:44 PM
