1. europa315's Avatar
    When I enter recovery mode, I get a message "Downloading, do not turn off!" I don't know how I got to that point or why I can't access the recovery menu options. If I hit the power button, I just go into the bootloader sequence and restart my phone.
    02-07-2012 12:59 PM
  2. mclarryjr's Avatar
    Did you flash a custom recovery?
    02-07-2012 01:29 PM
  3. Knyte's Avatar
    I get that too and as far as I know it is stock.. VZW sent mine as a CLNR.. I am guessing this screen isn't for stock recovery?
    02-07-2012 01:34 PM
  4. Knyte's Avatar
    Holding only volume down and power brings up this screen called Odin mode(I think).. NO idea what Odin mode is..
    02-07-2012 04:23 PM
  5. URPREY's Avatar
    That isn't the recovery screen. You need to hold the power and volume up and down to get to recovery
    europa315 likes this.
    02-07-2012 06:46 PM
  6. europa315's Avatar
    Urprey, thanks for the help! I didn't even think to try that button combo!
    02-08-2012 09:59 AM
