- 02-08-2012, 01:57 PM
Thread Author #1
Does This Speed Test Result Look Right for a -83 dBM 4G Signal?
Here is the Speed Test (I always use this server so the results are consistent):
Here is the screen shot of the signal strength (-83 dBM):
- 02-08-2012, 02:22 PM #2
- 02-08-2012, 02:27 PM #3
Re: Does This Speed Test Result Look Right for a -83 dBM 4G Signa
There isnt really a correlation between signal strength and speed...
you can have the strongest signal possible, but if everyone else is pulling data from the same tower at that moment, then your speed will always be slow.... - 02-08-2012, 02:35 PM #4Former moderator & advisor.
HTC - the One to rule them all.
- 02-08-2012, 02:59 PM
Thread Author #5
No, server is not the one closest. The one closest to me gets about the same speeds, but the reason I use this one is because this is the one that the app sends me to automatically. So since that is the one I have always been sent to by the app, I have not changed it except to check to see if I could get any faster speeds from a closer server and I couldn't.
- 02-08-2012, 03:00 PM
Thread Author #6
- 02-08-2012, 03:05 PM #7
- 02-08-2012, 03:20 PM
Thread Author #8
- 02-08-2012, 03:26 PM #9
OT...... how do I take screenshots if I am NOT rooted?
- 02-08-2012, 03:28 PM #10
- 02-08-2012, 05:10 PM #11
- 02-08-2012, 06:34 PM #12
- 02-09-2012, 08:39 AM #13
- 02-09-2012, 04:26 PM #14
- 02-09-2012, 10:16 PM #15
THe OP's issue is cell capacity in his/her area, not the signal level. I would contact vzw and tell them about the capacity problem. They advertise 5-12mbps down and 2-5 up. You're seeing less than that and have a valid case.
Verizon 4G LTE
- 02-09-2012, 11:52 PM #16
- 02-10-2012, 12:10 AM #17
Have you tried speakeasy.net/speedtest from the browser? I've noticed slower speedtest.net speeds since I installed 4.0.4. Its a bug in how the app/os talks (its happened in the past). Speakeasy.net has always given more consistant results.
These were taken in the same day in the same area. Different times, but only a couple of hours.
Speedtest.net (which blows)
Speakeasy.net (love this site!... we have flash, use it!!!)
- 02-10-2012, 02:08 AM #18
- 02-10-2012, 08:00 AM #19
Gnex Girl I ping off of that same server and get crappy speeds as well. Including higher uploads than downloads. I believe it is the server. I went to Nashville a few weeks ago and was getting better speeds.
Reply
