Results 1 to 4 of 4
    Evil Hamster's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Wifi Tether w/ XBOX 360 won't work.
    It worked when I had a Rezound. I traded the Rezound for a Nexus and everything will connect to the wifi except the Xbox. Does anybody have any suggestions?
  2. #2
    Patrick Schroedl's Avatar
    Retired Moderator
    Posts
    Global Posts
    3,827 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Wifi Tether w/ XBOX 360 won't work.
    My Xbox 360 works with it. I don't use authentication or a "whitelist" (MAC filtering) when connecting my Xbox, I've had issues there in the past.
    Edit: to be clear, are you unable to connect to the network at all? Or can you connect to the hotspot in a limited fashion (i.e. no internet access)?
  3. #3
    eleeezy's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Mine works, just had to use the password that was automatically generated...when i changed the password, it didnt work
  4. #4
    Horr1bleK1tten's Avatar
    Posts
    Global Posts
    305 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default
    My Xbox did that at first you can't have a password for it to work set password as open
    Sent from my SGH-T989 using Tapatalk
