E Evil Hamster Well-known member Oct 23, 2011 65 0 0 Visit site Feb 9, 2012 #1 It worked when I had a Rezound. I traded the Rezound for a Nexus and everything will connect to the wifi except the Xbox. Does anybody have any suggestions?
zkSharks Retired Moderator Mar 15, 2011 2,013 75 0 Visit site Feb 9, 2012 #2 My Xbox 360 works with it. I don't use authentication or a "whitelist" (MAC filtering) when connecting my Xbox, I've had issues there in the past. Edit: to be clear, are you unable to connect to the network at all? Or can you connect to the hotspot in a limited fashion (i.e. no internet access)?
E eleeezy Active member Oct 20, 2011 42 1 0 Visit site Feb 10, 2012 #3 Mine works, just had to use the password that was automatically generated...when i changed the password, it didnt work
Horr1bleK1tten Well-known member Oct 20, 2011 359 13 0 Visit site Feb 10, 2012 #4 My Xbox did that at first you can't have a password for it to work set password as open Sent from my SGH-T989 using Tapatalk
