Wifi Tether w/ XBOX 360 won't work.
Evil Hamster
65
It worked when I had a Rezound. I traded the Rezound for a Nexus and everything will connect to the wifi except the Xbox. Does anybody have any suggestions?
My Xbox 360 works with it. I don't use authentication or a "whitelist" (MAC filtering) when connecting my Xbox, I've had issues there in the past.
Edit: to be clear, are you unable to connect to the network at all? Or can you connect to the hotspot in a limited fashion (i.e. no internet access)?
Mine works, just had to use the password that was automatically generated...when i changed the password, it didnt work
My Xbox did that at first you can't have a password for it to work set password as open
Sent from my SGH-T989 using Tapatalk
kuzmaj05
