- 02-10-2012, 02:44 PM
Thread Author #1
galaxy nexus battery life
I've had my galaxy nexus since the day it came out on verizon. I bought a Mugen extended battery (2000 MAH) and i still can't get 10 hours out of the device before it dies on me.
I'm rooted and running 4.0.4, the stock rom.
Any suggestions on what i can do?....because this is ridiculous - 02-10-2012, 02:59 PM #2
Re: galaxy nexus battery life
How much do you use your phone though?
If you have your phone out and are using it for 5 hours a day, your numbers sound pretty normal.
If you barely ever touch your phone during the work day and its dying that quick, then you may have a problem.
Needs more infos!
- 02-10-2012, 03:01 PM
Thread Author #3
- 02-10-2012, 03:19 PM
Thread Author #4
- 02-10-2012, 04:06 PM #5
Thats normal. I get about 3 hrs screen on time w 2100 oem battery. But i can make that 18 hrs on one charge.
Thanked by: - 02-10-2012, 04:13 PM #6
I get an average of 2 hours of screen on and 15 hours with LTE on all the time syncing everything. It may be due to your purchase of a third party battery. OEM batteries are usually 95% on thier utilization of thier listed mAh where as third party batteries can be as low as 70%. You may find that you get better battery life on an OEM with less mAh. Try with your original battery and see what you get. I believe that Verizon is still running their 50% off accessories sale so the 2100 mAh OEM would be $25.
Thanked by: - 02-10-2012, 04:15 PM #7
Are you streaming videos etc during the on screen time? I have noticed streaming video kills my battery faster then anything else, even over wifi. I am currently at 7 hr 54 min on Battery with 50% left. i am still on stock 4.0.2. My screen on time has only been 51 min. All i have done today is look at friendcaster a few times check 1 website for about 10min, check gmail and send a couple texts. Been at work so not much time to use the phone.
- 02-10-2012, 04:19 PM #8
Download badass battery and see what's using draining it
- 02-10-2012, 04:22 PM
Thread Author #9
- 02-10-2012, 04:37 PM #10
- 02-10-2012, 04:46 PM #11
If you're not getting 3 to 4 hours of screen time from your battery, you've got some apps that are not running well installed on your phone. And after market batteries suck!
Semper Fi
I love my LG Nexus 4!Thanked by: - 02-10-2012, 04:53 PM
Thread Author #12
that's weird. Sleep mode is similar to stand-by mode and should use minimal battery power. I would suggest just turning your phone off if you're not going to use it all day. It takes probably a minute to start up, so it's not THAT big of a disadvantage to just turn it off.
- 02-10-2012, 05:13 PM #13
- 02-10-2012, 05:22 PM #14
- 02-10-2012, 05:31 PM #15
You could read the hundreds of threads and post. Heck bump it up thousands of post n threads with other phones. You have a super phone its made to b used and abused not pampered if u get 6- 7 hours thats normal.
Sent from my Galaxy Nexus using Xparent Cyan TapatalkGoogle Nexus Class Devices (Nexus7, Nexus4, Galaxy Nexus lte VZW)...@moosc on twitter ...
- 02-10-2012, 05:37 PM #16
It wont help at all and will then get you starting threads about how your gps takes forever to get a lock when you start it up. My gps uses .1% of my battery (assuming I don't do any navigation that day).
This is an app/apps problem. As suggested, download Badass Battery monitor and see whats eating up your juice.Semper Fi
I love my LG Nexus 4! - 02-10-2012, 05:39 PM #17
its a smartphone, plug it in when you can. Charge at night, in the car and you'll be good. Yes it could be better and it probably will. My Droid x lasted longer but I ain't going back!
Sent from my Galaxy Nexus using Tapatalk - 02-10-2012, 06:28 PM
Thread Author #18
- 02-10-2012, 06:30 PM
Thread Author #19
Reply
