Results 1 to 10 of 10
    md308's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Nova Launcher help
    I got Nova before I was rooted so I lost the widget preview in the app drawer. I have since rooted and flashed 4.0.4. Beta14 for Nova says the widget preview should work with root now, but the option for it in Nova settings is still grayed out for me.
    I searched XDA forums and saw someone else had the same issue, but no one offered any help. Any suggestions what I need to do?
  2. #2
    greydarrah's Avatar
    Posts
    Global Posts
    5,991 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Default Re: Nova Launcher help
    You could this:
    Uninstall/delete your current Nova (first set your launcher back to the default launcher)
    Download the NovaLauncherUpdate.zip from the xda Nova page (in the first post)
    Flash the NovaLauncherUpdate.zip like you would flash a kernel (from reboot recovery, just clear cache and dalvik first...NOT a data wipe)
    After rebooting and selecting Nova as your new default, go into Nova and tell it to update.
  3. #3
    moosc's Avatar
    Grand Master Moosc
    Posts
    Global Posts
    5,618 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    AKOP M4 old geezer theme
    Default
    Or go into data apps move nova to system apps then reboot this is using root explorer
    Sent from my Galaxy Nexus using Xparent Cyan Tapatalk
    md308's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by moosc View Post
    I tried this route, but get an error that I cannot paste to system/app because it is read only...
    md308's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by greydarrah View Post
    You could this:
    This worked, just have to reconfigure everything in Nova again now.
    Thanks to you both for the help.
  6. #6
    greydarrah's Avatar
    Posts
    Global Posts
    5,991 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by md308 View Post
    I would think that if you had a Nova backup, it could still be restored, but I could be wrong.
  7. #7
    Drootz's Avatar
    Posts
    Global Posts
    171 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    GB & ICS
    Try this make sure you have root explorer set to read/write and not read only. That is most likely why you got the error.
  8. Thread Author  Thread Author    #8
    md308's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Quote Originally Posted by Drootz View Post
    That was the case. Thanks for the tip!
  9. #9
    moosc's Avatar
    Grand Master Moosc
    Posts
    Global Posts
    5,618 Global Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Carrier
    Default
    U know right after u set up go into nova settings and back it up.
  10. Thread Author  Thread Author    #10
    md308's Avatar
    Posts
    Mentioned
    0 Post(s)
    Tagged
    0 Thread(s)
    Will do!
