tx_tuff
If you are using your phone on WiFi you can get some good battery time, just like above with 5 hours of screen time on 14 hours total. Of course I'm sure the screen wasn't site above 50% brightness also (which you don't need anyway if using indoors). I have gotten this type of battery life on mine at home (WiFi) also.
But away from on with 4G on and heavy use (say streaming netflix) I can get as low as 4 hours on the phone. Just depends on how and where you use it, including type of data, brightness of screen etc...
