Results 1 to 5 of 5
    ottomatic78's Avatar
    Posts
    Global Posts
    2 Global Posts
    Default Squelching sound while talking??
    I have had many people complain that when I am talking to them they hear a ear piercing squelching sound on their end. I don't hear this when they do but it definitely seems to be my phone. Occasionally I can hear it intermittently and it is quite loud and annoying. Has anybody else had any problems with this or heard of anyone else having this happen? I did search the forums here and can't seem to find any other users having this problem.
  2. #2
    JkdJedi's Avatar
    Android Enthusiast
    Posts
    ROM
    SKAnkCM10/Milestone6
    Default Re: Squelching sound while talking??
    Quote Originally Posted by ottomatic78#ac View Post
    Same here, and its across different ROMs so I know its the phone. Not sure what to do about it.
  3. #3
    I have had it also. I also have Google Voice installed. Do you also have G/V installed? Using their lines seems to cause problems sometimes. If you switch to "Ask every time you call" on which to use for calling, "Google or Verizon" try selecting Verizon. It seems to help.
    Thanked by:
  4. #4
    JkdJedi's Avatar
    Android Enthusiast
    Posts
    ROM
    Quote Originally Posted by 1Brite1 View Post
    I will certainly try that, thanks!
  5. #5
    I get blasted by that frequently, lasting 1-2 seconds. No GV involved.
